what bulbs are you after? parker lights, plate lights, interior lights use t10 bulbs.
after HID! h4 ???
in that case h4's will fit if not look around the headlights for some codes/numbers
Hai, I'm going through the same thing at the moment. Got my H4 HID kit however I don't have the stock clamps to hold them in so have ordered them in through Honda - 3 week wait. Stock HID kit was using D2R bulbs so not too sure if the H4s will fit. Will let you know in three weeks time haha.
Just spoke with my friend who works as parts interpreter at Honda. He told me that if you are using the OEM clamps to hold in the bulbs then H4 will not fit. You need to get a D2R HID kit.
The HID kit from Honda costs $3-4k. :S
Is anyone running Buddy Club N+ coilovers on their EP3? The installer wasn't able to get the tie rod ends to sit completely into the hole on the coilovers. Hence, I can't use the cotter pin..
Any insight guys?
put an extra nut on the end & u'll be fine... add some loctite if you're paranoid about it coming loose.
Has anyone got their ep3 windscreens replaced?? Is it the same windscreens as the EU versions??? And where I could i get it replaced for a good deal? Thanks!
I had mine replaced at a Campsie Auto Glass for 368 fitted.
