has anyone had to bust open into their drivers side door?
i noticed there are 3 screws on the end is that all thats needed to open the door and access the lock?
There's likes 2-3 screws when you take the silver cover off, pull the under handle off and there's 3-4 screws. Once you've gotten that out unclip the bottom first working your way up the sides. Unplug the window switch, push the plastic lock out so you can take the metal cable up.
ep3 wheel, does anyone has the wheel on their ep3r with 8.5 and +30? how does it look?, do u need to work on something to make the wheel fit nicely?
I've played around with 17 8.5+35 love it, clears full steering lock both sides and sits pretty good on stock height. However you'll have to get your guards rolled if lowered more than an inch or two.
Damo did you manage to get the door off?
Hey guys, I love s2krazy's wheels he's selling, 17" Gold Advan RG's
Here are the specs
17 x 7.5 +48
17 x 8.5 +50
5x114.3
Now I'm pretty sure the offset won't work? Am I right? I love the design and colour, Ann ep3 friendly alternatives?
I know the stud pattern is fine but
17x8 +37 (unknown tyre size)
http://i613.photobucket.com/albums/t...g?t=1297165878
17x8.5 +32 (205/40's)
http://i613.photobucket.com/albums/t...g?t=1297165982
http://i613.photobucket.com/albums/t...g?t=1297165831
http://i613.photobucket.com/albums/t...g?t=1297166411
well our offset is 45 stock, i'd personally go for an offest 30<x<40 for abit of lip :) , too low you might have clearance issues?
