not after 22000kms,, they will last over 80000 KM easy
so i just gotta be careful when prying off the valve cover, as to not damage/cut the gasket?
also the mechanic that replaced the valve cover gasket, used liquid gasket all the way around the gasket. is this need?
You will need to apply gasket goo around the corners especially where the cam seal is and around the dizzy area as those tend to leak easy.
Gasket goo from supercheap or any auto shop.
sweet thanks mate. i got Permatex Ultra Grey. i got a new cam plug aswell, seeing as its leaking again from when i tried to fix last time.
The old gasket sealant will just pull off easily.Wipe it/clean it up with a rag and apply the new gasket sealant.Then tighten the valve cover bolts in the correct order.Just google an image search.
i have the workshop manual for the EG, all good. nice to help other but, cheers for that.
Good good :)
there are no hot specs, if you read the first page you will see it stats they must be done cold.
Ill see if I can fix the links
That`s it then mate,cause there are no hot OR cold specs,just specs.And you do it when the engine is cold.
