that's aids.... that won't happen D:
When trying to get the resistance should the headunit/engine be on? The sound only occurs when the engine is running- and do I have to disconnect the ground cable from the amp?
I've connected the speakers by:
- cutting the harness out. Leaving 4 stripped wires.
- 2 of the wires were DIRECTLY soldered onto the speaker
- The other two remaining ends has been duct tapped
- Today, I've just overloaded the terminals with duct tape. I even went to the extreme of duct tapping the door metal just incase there is a loose end. I think it made it somewhat better :) Need to play it more to notice-
LOL I always get the same message! TbM deserves to be repped more!!
Yeah I guess you could describe it like that. But you will certainly have that "feeling" in your ear after a concert. But this issue here is that my system IS NOT that loud and my ear has that same feeling. SO the sound is kinda invisible if that makes any sense.
Lol, yeh its a bit annoying
No, your checking if there is continuity between the speaker cable and chassis
no, just disconnect the speaker cables from the amp and test them.
Ive never herd of using duct tape for wires, i use electrical tape.
Okay I've did a continuity test between the speaker and chassis.
Results:
- On default the reading on 200 ohm (lowest level) is 1
- When black is on chassis and red is on each speaker cable the reading does not change. Still at 1 (This reading is the same with + and - of BOTH speakers)
Is this ok?
Hmm I think I'm using the wrong terms for duct tape/electrical tape. Yeah I think I was using electrical tape (its black and smooth)
by 1 do you mean infinite? if its like this then its infinite and your all good.
http://www.outilsobdfacile.com/softw...r-original.jpg
Yep! exactly like that.
This is strange, I'm almost certain that the speakers are producing some sort of sound that is irritating my ear. My left ear only car hear about 70% of sounds now, I hope it gets better tomorrow...
is the interference problem fixed now you have stopped your terminals grounding out?
