Originally Posted by
nikos
Forgive my ignorance but I need to ask a few things about open and closed Loop in K pro.
So when running the motor in closed loop, the computer adjusts the fuel so that the A/F ratio is ideal. In open loop, the car runs strictly off the fuel maps that are in the calibration. That is what I understand so far..
My questions are:
1)If the computer adjusts the fuel on its own, why do people street tune before they hit the dyno to adjust the a/f ratio?
2)I understand that when tuning on the dyno, it needs to be in open loop.. but when the car is in closed loop, is there a way to see the adjustements the computer is making to the fuel values?
Basically, I have this calibration that kicks ass on my car, but in open loop a/f ratio on K pro is crazy high... so I have to run it in closed loop.
Can a calibration loose power from switching from closed loop to open loop?
Last question.. Some people are telling me that the stock 02 sensor is not very accurate and that I should go by the readings of a a/f sensor that gets stuck in the exhaust during a dyno session.. and basically not to worry too much about the Kpro A/F reading... I find that hard to believe.. any input?
I basically want to be able to use that calibration on a daily basis without risking going lean.
When datalogging on the street, is there a point into doing it while in closed loop? Or should it always be in open loop so that the user can see the actual a/d ratio...
Sorry about these questions, but I need to understand this 100%
