-nuke-
-nuke-
I'm not sure if I'm reading this right, but aren't both motors 1.8L in capacity:rolleyes:Quote:
Originally Posted by string
seriously.... there is like more then 20 kw diffrence with the b18b and b18c in stock form right? isnt it common sense that the b18c will make more power with the same setup used for both engines?
well, at least someone is making an effort.Quote:
Cost wise, fair enough, it may be more economical. There are a lot of people basically saying that it's a better engine from a technical standpoint. That's what I'd love to hear about.
-nuke-
-nuke-
-nuke-
Um yer cool but did you miss the point when i said to compare a stock b18c lolQuote:
Originally Posted by 2MPRSS
Haha you cant be serious can ya? A pig down low....erm if only you knew. Yeah sure4 it would be a pig down low if ya using the wrong size turbo and it takes forever to spool up but mate if people were wise they'd use a smaller size turbo etc etc etc. I honestly dont think a b18b would be quicker than a b18c using the exact same setup as what ive got but seriously guys, all ya doin is making up alot of crap to try proving a point thats already been proven.Quote:
EXACT SAME TURBO SETUP WITH BOTH HEALTHY ENGINES THE B18C HAS BEEN PROVEN TO HAVE MORE POWER ON THE DYNO
but get a b18c or b18b with high km thats tired and your kw will drop. (as this was the case with my first engine)
I have not once said in this thread that a b18b will have more kw than a b18c and there are definate facts that the b18c should be a stronger option. But at the end of the day when ya on the track its down to the driver when the lights go GREEN :cool:
what point?a stock b18c has more power then a b18b doesnt?whats ur point again didnt understand?Quote:
Originally Posted by GSI-PSI
the point I was trying to make in that regards is that the b18c, given an identical turbo set up, will show a greater increase in power than the b18b on the dynoQuote:
saxman are u and gsi psi same person?i was refering to him but again thanks for ur awnser and thats what i really ment on my previous post,sumone should close this thread
