with the gear ratios... you can pick up the mFactory 4.64 or the 5.2 Final drive for the H-series... that should fix the problem. Its pretty popular is the US. :D
H-series all the way!!
A H22A box with a 4.7 final drive and 22" slick is a good combination to run 115mph at 8,000rpm in 4th. :)
Thats if you use Hasport mounts. Make your own and position the engine where it should be. You may need to do a little surgery under the car and to the firewall at the bottom though. ;)
True as well.
I knew what you were saying. ;)
Go the H22a.... 13.2 @ 112 (wheel spinning) with only a cat-back (standard headers) and CAI. Not far off what K's are doing...
HCP Engineering Engine mounts & A/C bracket, Hasport rear trans mount.
Tyres are badly worn Falken Ziex's 205/50/16's.
very nice.
fark 112MPH thats massive. Im pretty sure its not a stock engine
I would say. stick to the k20a... more stuff its being developed compare to h22a.
h22a is getting older.. its been arround for awhile. while the new generations gonna take over it.
well from what i knew off. mate of mine back in indo had a H22a turbo fully built engine for drag on an eg hatch.. hardly touch 10 sec on 1/4 mile due to traction.. always on lows 11..
and still drive able on street. not so bad. but only at nightime :p lol!!
well dats some idea...
