Thanks!
Thanks!
I failed the MVR pits because of my HID lights how do I get around it. I went to an auto lec. They reckon I'd should look into finding some second hand ADM headlights that might fit. They think it will be too hard, time consuming and may not work if we try to swap to normal globs. what should I do? Is there a forum section on this?
That's bullshit. My compliance guy swapped out my hid and replaced with normal heligen. It was quite easy to hook up. I remember it was only 2 wires run off from the plug that hook up to the HID ballast.
He kept my HID bits so I could return everything to OEM HID relatively easily.
Yes!!
Ok just went to the garage and managed to find the wiring and light bulbs I pulled out to put the HID back. I recall I took some pic on how they are connected to the plugs. Lete have a look later.
Really!! ok no worrys I guess my complacence guy should have done that too. Dodge bastard. I'll find a diff auto lec and get them to do that. Thanks heaps
Sweet I'll come back later for a look see cheers
Oops I just remember mine is facelift so the wiring is only for low beams. But let me find the pics so u can show your electrican for reference.
i have problem uploading pic. KIKNHRD please PM me with your email.
thanks
PM sent
We tried today to put the halogens in and disconnect the ballast. Due to only having one globe and high and low beam controlled by the sleave that moves back and forth. We could not get high and low working properly. looks like I may need to purchase a second had set of lights to put in so I can register it, then switch back. Does anyone know what lights would fit a preface lift ep3 (none HID)??
Depends on the clips that you have in there mate. You could just get H4 bulbs and then modify some pieces of wire to hold the bulb in.
Just got my Mugen front lip installed today, come home to park it in the garage and SCRAAAAPE - a huge chunk of paint is now missing. FML.
