niceeeeeeeeeee
niceeeeeeeeeee
Can anyone recommend a few good B20 frank builders in sydney? I will be building this one right with new bearings, rings, pistons, studs etc.
I was considering dyno dave but apparently he isn't around anymore?
Byp in the trader section can sort you out
I think you heard wrong :p
Dyno Dave is still building b20s
91 pages later lol
Has anyone tried different ignition setups on the builds they have done? Like the coil over plug setups that are going around or is everyone just using standard vtec head ignition setups?
If using a b18 block with a girdle is it possible to use the longer stroke crank and does the girdle need to be massaged to compensate ( not doing this but curious as to it's Clarence )
If anyone has done head work, how much meat is there to play with before running into galleries etc? Also do you have cc's per runner or end flow rate results?
How much is the going rate for sleeving these days? Going by the majority of people's results not really a necessity but ale
Ways good for piece of mind and maybe some
Boost if I win lotto lol
By the looks of things these days the b20 is a bit of a dying trend as the new k packages are simple enough with good results but still looking to play around a little for a bit of education.....
91 pages later lol
try to contact dyno dave... if u want to build one.. or even tinkerbell
How does the frankenstein engines affect insurance?
It won't affect insurance.
So do you declare an engine swap?
