you can't compare wheel and hub dyno's man
TODA dyno is the most relistic I believe I believe
Ahhhh, the bottom one!
If you are going to top up, you must top it up with the EXACT same oil. You can't mix oil brand or oil with different viscosity. Reason for that is because different oil have different additives and the effects of mixing them is unknown.
How many kms have you travelled since your last service with dedy?
Well guys cluch is on the way out...slipping in the higher gears. Does anyone have the spoon or mugen clutch? I know alot of you run the exedy, just wondering whether cost is the main reason for that.
How many kms on your ep3?
I doubt spoon/mugen is that much better. Most of the $$$ spent is towards the branding imo.
How's fuel economy going for you luke?
can anyone tell me the part number for ep3 oem window visors?
Cheer
hey ben how'd you go on the track?
