dam they are a very nice looking rim. Would look pretty awesome on a ep3
Pete, Sell the stock wheels and re use the tyres lol
What's a good brand of clutch for the ep3???
Thanks nepo
brake fluid 2 bottles
Thanks!
Hey guys,
The CEL came on yesterday and I thought it was just the oxygen sensor...did the little paperclip pin thing and It came back with code 23 which is the Knock Sensor Circuit Malfunction. Reset the ECU thinking it was just a one off thing...it came back on today. How can I check this problem? I can't take it to my mechanic due to the public holiday. Any advice?
you got a open circuit on the knock sensor. check the pins to the knock sensor. remove the plug, check the connectors, spray a contact cleaner n replug in and reset. make sure connection is secure. Reset cel. if cel comes on again, chg the knock sensor.
noticeably dank smell from in or around fuel pump cover. Should there be any vented scent at all ? possible failing fuel pump or ?
