usually oil vapour luke does that. Mines the same in places.
WTF! Vtecing too much lol....
Quite common. I've seen a few ep with cracked paint or loss of paint.
mine's started to crack :(
I may buy a brand new one when I do my valve clearance. They're about $300ish for a new one.
When you have time, get the old one sprayed and sell it. Or maybe just sell as is to recoup money. That's my plan.
I see cracks!
I have peeling in one corner. Doesn't seem to be getting any worse though. *Touch wood*
Is there that much variance in the type of compressor used to pump your tyres? Can someone explain the idea behind it, as it's a bit odd to think that where you inflate your tyres would have any significant impact on on-road performance (esp power figures on a dyno).
LOL. I was thinking the same too.
Whatever they are pumping, it's still the same gas that we breathe from the air I believe.
No no no munki and the poiter....you have it way wrong. The air produced for special compressors, as mention give out much denser air (similar to the air super steve and I breath). Now without getting too tethnical, this special air will load the side walls of your tyres more hence more grip and will also keep air temps down.
I hope chubby steve will chime in as he was the master of this art. There was a rumor me cheated when obtaining a fast WSID run by tapping this air into the cai giving the car secret super powaaaa!
Would like the hear the technical side of it, I'm just trying to get my head around it :). Just using what I learnt from uni..
If we assume that air is an ideal gas, and that you are trying to pump more dense air into the tyre.
P = density * R * T
Then more dense air implies that at a given pressure, you will keep temps down as you mentioned above.
By loading the sidewalls, do they flex more or less? (Don't know much about tyre deformation) I would think they flex less so that they can put power down better? Would you run any different tyre pressures given the more dense air?
Edit: Cooler Tyre Temp = Less elasticity in the side wall = Less Flex?
Or am I WAYYY OFF. Let me know! Would love to learn.
