I've got a headlight if you need one.
were you at unsw today man??
i got rear ended today. seems like a bad day for us EP3 owners
i nearly got hit in my right fender by a ute on hume hwy today and the bogan said it wasnt his fault for merging into my lane like a wanker.
Just installed some Shifter base bushings and Shifter cable bushings
http://forums.clubep3.com/showthread.php?t=755372
http://forums.clubep3.com/showthread.php?t=755772
Gear shifts are even better now! Definitely a worthy mod.
This guy in a SSS was tailing me and then i had to break he had no time...NEARLY ran straight up my rear...BUT defensive driving kicked in and I swerved around the car infront across double lines and went the wrong way through a roundabout..LOL....The guy nearly hit the car infront of me.....Full fail driving ...from kebab spec SSS.
Bit of a random question. But has anyone here ever fitted the stock EP3 wheels onto a 180sx/s13/s14/s15 or even a r32/r33 before??? If so did they clear the front calipers?
i highly doubt it will clear r32/33
hey i was wondering if you guys could help me out, i recently change my springs on my ep3 and i've noticed a knocking noise when i turn, i took it to the mechanics and they said something about my tie rod bolts being loose. would any of you guys know how to fix the knocking noise or what bolts i would need? thanks.
Umm... Tighten the tie rod bolts? Also check the to nut on the strut too. 17mm if I remember.
