Hey guys, just wanted to say ill be joining the family with a white EP3 I recently purchased..
=P
=P
Hey guys, driver side window suddenly stop working. Any ideas?
^^ try disconnect and reconnect battery, it will reset your power window system..
try this turn your key to 2nd click, hold your window down like auto down for 10seconds. turn it off, back on again and auto up should be working again
both failed
:( oh noo... burnt motor maybe, check your window seals.. if they are old and cracked that might be the reason of the window getting caught going up and down, therefore causing stress to the motor for it to give up..
ive already replaced the seals and they still look perfect. I have to check the switch but im lazy to pull the door apart again.
Check under dash fuses....
