only means one thing. bankruptcy
Who is coming to the cruise today, off to pie in the sky
try ebay? http://www.ebay.com.au/itm/Acura-RSX...item45fc4937f6
does anybody know if the header would fit with the stock jdm catyl ?
Correct ^^^ you'll need an aftermarket cat to be welded up where the test pipe is.
The stock cat is a part of the 2-1 section from the stock header. It would be a lot of trouble to make it fit. Sure it could be cut it up to fit onto the Kiddracing item, but why would you bother??? Plus you'd have to cut up your mid pipe section to make it fit & your o2 sensor wiring probably will need to be lengthened/extended to suit.
Only pic I took of the install:
http://i613.photobucket.com/albums/t...g?t=1317641415
Are the gasket sizes common? I don't think mine came with gaskets...
Yep, it is a standard 2.5" 3 hole gasket. I got it from my local Autobarn, probably a tad cheaper if you go to an exhaust shop. The other side you use the doughnut gasket supplied. Pretty sure you can get them from exhaust shops too, in case it didn't come with it.
Awesome, cheers
guys im in need of tie rod ends, jdmyard cannot be of any use fml. can someone point me to the right direction? thanks
