water temp sensor install on B18C7
Hi all,
I am a bit confused by the following instruction, grateful for your help.
"25) There are a number of places you can tap into for coolant temperature readouts but the OEM location is the most accurate. Simply tap the BSPT hole to 1/8-inch NPT threads, install a tee fitting and thread the new sending unit in place along with the OEM one. Now the stock gauge works along with the new aftermarket gauges."
Here is the image, can you tell me what is a "Tee fitting?!?" and where can I can buy it? I don't want to cut my radiator hose...
http://i278.photobucket.com/albums/k...ps1nououpc.jpg
