Help Needed: d16a8 to d16y4 conversion
Hi all, I have a 93 eh9 si with a broken d16a8 motor. I have bought a standard d16y4 motor. I plan to convert this in while still running the d16a8 gearbox. I later plan on putting on a y8 head.
Now I am confused in terms of wiring the motor. I have the ecu off the y4 and have access to the standard wiring harness aswell. I am wondering what I can do to make this work?
I know that the car is now running on an obd1 ecu, and the y4 ecu is a p2k, is this an obd2a or obd2b ecu? Also, what conversion harness will i need? Can I put the d16a8 intake manifold on the d16y4 head to make the wiring easier? Will I need an obd1 distributor?
