Hey guys i just formatted my computer ok and FIRST website i went on is Ozhonda. I dont even have icq yet.
And 5 minutes later i get the spyware popups? I havent been on ANY OTHER website...
Mods?
Mods?
what sites are poppin up?
belongs in site discussion i think.
BOT - what " pop ups" are you referring to ?
A computer sydstem is most vunerable , at its totally refresh. ( since no backup / updates etc are running)
Download these programs to help you out - SPYBOT , hijackthis , adaware etc (all free downloads) and they should help kill off most spyware.
NOTE When running one of these progs , open the programs, hit cntrl+alt+delete to access your tastk manager , go to processes , select all user-based running processes including explorer.exe and end each one - then run the programs' scan ( for best chances to catch out any spyware progs.)
After its finished click on "new task" and type in "explorer.exe" to access your windows gui again.
good luck. . .
it pops up a window that usually advertises something...
The window that pops up is a plain text window with an "ok" button that gets rid of it if u click it.
The ads that pop up are ironically ones that advertise programs that get rid of adware.
I don't think if would be ozhonda, more then likely you went to a site that had a pop up
they usually lie dormant until u close your comp down and start it up again
probably changed your registry as well, u might need to format your comp or use Hijack this to get rid of the pop up.
I really doubt it's Ozhonda.
Sounds more like your computer.
Get a spyware removal program (run a couple)
so do i... but i dont see any other reason for it as ozhonda was the FIRST AND ONLY site i visted after a fresh format?
do you run xp? have you got the latest service pack?
otherwise if its 2 much trouble use mozilla
If Ozhonda had an issue with Spyware, why hasn't anyone else had the same problem. I mean, out of several thousand members. :rolleyes:Quote:
Originally Posted by **Ghost**
As wynode suggested, get yourself a good Spyware removal program.
Here's a place to start:
http://www.download.com/Spyware-Cent...0.html?tag=dir
:thumbsup:
http://www.microsoft.com/downloads/d...displaylang=en
the best spyware removal I've seen to date
I wouldn't say the best. As you will notice you get best results running more than one of these programs as they all pick up different things on your system.Quote:
Originally Posted by bigteethygrin
When you say fresh does this mean you haven't installed any other software as well? As you will find some programs install spyware, malware without you even realising and this can cause odd behaviour such as pop-up from your favourite site :D
