Aim: To Adjust Valve clearances on Honda Engines
Required:
10mm ring spanner
flat blade screw driver
3\8 ratchet
3\8 bar
10mm 3\8 socket
17mm 1\2" socket
1\2" braker bar
1\2" bar
spark plug socket ( optional )
Ultra Grey
feeler gauge
touque wrench
some mechanical knowledge
just some advice before we get started
if you dont understand what I have written below. DONT TRY THIS
if you dont have the correct tools DONT TRY THIS
if you dont have the correct specs for your valve clearences DONT TRY THIS
if you dont read the entire post, and dont know how to adjust tappets DONT TRY THIS
if your not confident DONT TRY THIS
if your engine is not stone cold DONT TRY THIS
Make sure you have the correct valve clearences specs for your engine. pay special not to the difference in the inlet and exhaust clearances, dont mix them up.
your engine MUST be Cold
STEP 1
http://ecu-man.com/automotive/honda/diy/tappets/042.jpg
remove the rocca cover by undoing the 5 bolts shown above in red. unplug the leads and PVC tube, shown in green. (optional) undo the spark plugs, help when you turn the engine round
STEP 2
http://ecu-man.com/automotive/honda/diy/tappets/043.jpg
remove the cambelt cover, undo the two 10mm bolts shown in red, remove cambelt top cover
STEP 3
http://ecu-man.com/automotive/honda/diy/tappets/070.jpg
put a 17mm socket on a long 1\2" bar and connect it to a breaker bar and place it on the harmonic balancer bolt. ( you can go through the cover, you dont need to remove it like I did ) you can jack up the front of the car if you want and remove the wheel, make sure you use jack stands. But you can do this with the car on the ground and turn the wheel full lock to the left.
Step 4
http://ecu-man.com/automotive/honda/diy/tappets/064.jpg
turn the engine over from the breaker bar counter clockwise till you see the UP on the cam sprocket pointing up and use the markings on the harmonic balancer and cover to line up #1 cyl TDC. Note the position of the cam sprocket, you will see the markings on the sprocket will line up with the flat surface of the head. see yellow boxes above.
STEP 5
http://ecu-man.com/automotive/honda/diy/tappets/071.jpg
CYL # 1 is TDC ( top dead center ) red section, you can grab the top of the tappet and lift up/down to confirm, it should move up/down slightly.
place the correct feeler gauge for your engine specs between the valve and tappet.
- push/pull a few times to get the feal of the clearance.
- it should feal snug, not to tight and not to loose.
- if its tight back it off, if its loose, tighten it up to do so
- place a 10mm ring spanner, feeler gauge, and flat blade screw driver on the exhaust tappet. see below picture
http://ecu-man.com/automotive/honda/diy/tappets/067.jpg
crack the 10mm nut to loosen it, only enough to be able to tuen the screw. turn your screwdriver counter clockwise to loosen the valve clearance, turn it clock wise to tighten the valve clearance.
Make an adjustment and hold your screw driver firm so it wont move, and nip up (not tight but tight enough to stop everything from moving ) the 10mm nut.check your clearance, do this repetivly until you have reached the desierd clearance. you may go to tight or not enough, may take 10 attempts, but as you get better at it you get it in 3 or less. When you got your final clearance put your spanner on the nut and screw driver on the screw. hold the screw driver firm and tighten the nut. do not over tighten as you will snap it. to not leave it loose as you will cause all sorts of problems. then check 1 last time the valve clearance then move to the next exhaust valve. do the same as above.
see this example video
then do the inlet tappets ( note they will have different clearances )
I always check the 4 tappet nuts and for that cylinder to ensure there tight then 1 final check of the valve clearance then move on to the next cylinder.
turn the crank shaft 180 degrees counter clockwise
the cam sprocket should line up like this ( look for the markings on the sprocket )
http://ecu-man.com/automotive/honda/diy/tappets/068.jpg
- you must now adjust cylinder # 3 ( green box ) inlet and exhaust
- turn the crank shaft 180 degrees counter clockwise hamonic balancer should be on TDC mark, this makes Cylinder 4 TDC
- you must now adjust cylinder # 4 ( blue box ) inlet and exhaust
the cam sprocket should line up like it did for Cyl # 3 in photo above ( look for the markings on the sprocket )
- you must now adjust cylinder # 2 ( yellow box ) inlet and exhaust
thats if for the tappets. now put it all back together.
- put the top cam cover back on and tighten the 2 bolts.
- clean the head surface where the rocca cover gasket will sit
- clean the rocca cover gasket on the rocca cover
- apply ultra grey to the gasket as shown below in the yellow boxes
http://ecu-man.com/automotive/honda/diy/tappets/074.jpg
- refit your rocca cover, torque it down to manufactuters specs. tighten bolts in a criss cross pattern.
tighten up spark plugs if you loosend them.
DO NOT forget to remove your socket/breaker bar from the harmonic balancer, I have seen mechanics forget this there and start the engine. the bar goes round and round and rips the fron gaurd open like a can of sardines :)
I welcome any questions positive or negative feedback any pointers of anything I may have left out. ( this makes sense to me, but yall may not understand it )
also you may note I removed a few extra parts than nessesary as I also did a timing belt on tis thing
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself nor Ozhonda take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own
