Fuse question
		I have a 7.5 fuse that blew on me which was connected to my gauges EG. the light in my cluster. I cant see anything now my whole cluster light is turned off. I replaced the fuse and turned head lights on and heard it sizzle away again. What could be the cause of this short circuit.
I recently installed amp in my car. Everything was fine for the whole week till now.
Help Help Help. I cant drive in at nite now.
		Are you sure it wasn't cos of your amplifier install recently Tien?
		Well thats what im sayin Julz. Thats why I mentioned amp. I dont see how amp relates to that fuse. Amp has its own fuses. If amp was creating short circuit wouldnt it pop its own fuse?
		i had this same **** when i had my car.. my lights worked for about 3 days.. then blew, and never turned back on..
but it was due to shocking wiring..
i doubt that'd be the case for you, since urs ain't a conversion or anything..
i'm assuming it's something to do with your audio system.. as it never happened before until recently..
		i had the same prob dude, im guessing cos u had to install the amp u dicked a bit around behind the head unit.  Make sure the dimmer wire isnt shorting behind the head unit.  That cost me $40 at an auto electrician cos it was pissing me off so much.
http://www.ozhonda.com/forum/showthread.php?t=14027
		Thanks dude, im thinking dimmer wire to. I was looking for the wire last night and it was a bit dark so I didn't know which one it was. By any chance does anyone know what colour cable the dimmer is? While you're at it whats the antenna wire too?
		no probs, does this mean ure coming 2 nite? carwash?
Antenna - yellow/green
Dimmer - Red/Black according to TI
http://www.team-integra.net/sections...?ArticleID=217
		Hey i got an illuminate which is Orange and white? Its labled ILL. Would that be the same one? You reakon i should just cut it then insulate it?
As for tonite. I was gonna come anyway LOL.
		BTW my dimmer is connected into the back of my head unit.
		u'd be best to up electrical tape on the end of all un-used exposed wires
the antenna wire is for when u put radio on the antenna goes up automatically..
ps. i didnt know u was viet.. i just read ur sign ahahaha
		Dude, Im Sp3rMz- = Mashimaro = Tien = Viet LOLOL....
Neways...i've taped everything up. Hope everything works. IM tryin to find antenna wire but i dont seem to have a green and yellow wire.
		what H/U u using?
mightn't have a antenna wire from the deck
cos it should have the label ANT on it
lol back to the Fuse question.. is it worknig?
