about to swap out my b18c2 for a b18c7 and need a wiring diagram as the loom I got with the engine had a plug cut off thanks
What colour are the wires
And where abouts on the loom
ill post up a pic in the morning
you dont need that part of the loom when doing the engine swap
oh sweet, curiously do u know what it is anyway
also have this cut
looks like underdash harness. last pic is abs plug?
it looks to be part of the rear wire harness
top part thats been cut off goes to the Drivers door harness and bottom part goes to the rear of the car
old engine is out now trying to figure out wiring
since these plugs are cut do u just cut the tape around my old loom and use my old door loom wires or is there a simple was that im missing haja
also im going from a 93 jap spec si to a 99 audm type r
you only need to swap out the ENGINE HARNESS. Unplug it between the two strut towers and it comes out with the engine
Don't need to touch the door looms, dash loom or anything else
alright so the fuse box out of my vti-r will be fine? they look completly differnt
if thats the case all I need is ecu conversion harnes right :)
where can I get the harness from cant find it anywhere
china
Pm lolmclol
He sells them
