hi every Ozhonda members,
I got a JDM DC2R (96 Spec) , now it's the time to change the rear rotors.
does any1 know which model (Prelude ?) the rear rotor can direct replace to my itr ?
my PCD is 114.3x4
thank you :)
my PCD is 114.3x4
thank you :)
why do you want prelude ones?
why not jsut get a replacement teg one?
prob because he cant source these new in Australia. Only via a part imported.
OR via a prelude that runs the same rear 4x114.3
afaik the only known options at the moment are getting regular 4x100 teg rotors and redrilling them to 4x114.3 then you have to bore out the center to fit the 96spec hub
otherwise fastbrakes.com from the us has them
lude ones are generally cheaper(cos of low demand) that's prob why
I am intend to get some better rotor other then OEM.
any brands can recomend me ? (RDA? DBA?)
p/s: for street use. thanks :)
go RDA for a cheaper alternative to DBA.
Or spend alittle more and get DBA.
Pm EG5 for both.
I asked him, & he told me buy from oversea.
therefore I need to do some research on RDA & DBA for which other model may suit my car...
Can any1 tell me what is the Centre Hole Diameter of my 96 Spec ? 70mm or 64mm ?
64.1mm
look up the specs for the dc2 rear rotor
only difference is 4x114.3 and 64.1mm center bore
if you end up finding rotors let me know, and the rest of honda-tech for that matter
no ones found a direct oem replacement other than the real-deal oem
if can found from prelude can straight fit in,
it will save me alot of time & troubles.
BTW, I got no idea how much it might cost me to redrill the PCD & Centre holes :(?
p/s: I m located in Melb
