Rev sits at 1100rpm when i just start the car, wen it gets warm up it sits at 1500rpm, its doesnt hunt or anything, the rev just sits high
Anyone know what the problem is?
what car ????
are you using a stock ecu?
Have you changed ANYTHING at all before the idle has changed, have you cleaned your IACV valve yet?
If the iacv is stuck or sticky it can cause the revs to sit high, it does not only cause the revs to hunt, do the revs ever drop to a normal level?
it doesnt do it randomly, wen it gets warm the revs goes up
Have you tried an ecu reset? is this ur vti-r your talking about? can you tell me what happens when you turn on ur AC once the car is warmed up.
Thanks
car doesnt have air con
lol
reset the ecu plenty of time, what will happen if i unplug the iacv?
try it out, i think it will drop the idle unless as i stated before it is stuck or sticky. but give it a go.
how do i test that my iacv is rooted?
check the ignition timing 1st
when you change the ROM the base timing migth change if the ROM has different ignition tables
use a timing light with a hot motor and bridge the SCS
