Unsure if you all know about this or not...just thought it good to post up!!
http://www.recalls.gov.au/view_recal..._ID_Auto=15998
Thanks for the heads up
I also found one for 0506 jazz - fuel lines recall
http://www.recalls.gov.au/view_recal..._ID_Auto=14742
i received letter from honda last month on the fuel pump relay. mine is gd3 2005.
Thanks mate, I almost miss that due to we moved, therefore we didn't receive any mail from Honda!!
hrmms i have not receive any mail yet... hope i don't
I've check my VIN#, it's within the recall numbers, but so far, I haven't receive any letter for any of the recalls~~ I remember they notified me about a fuel pump relay a while ago when I did one of my service, that's all.....might ask them why next time when I'm in~~
do i need to take out my intake (open pod filter), change it back to stock before i go to honda for the fuel pump relay?
I only just received the letter for the handbrake recall. I emailed the dealer about a month ago and they didn't have any idea about it until i send them the link =|
Affected Jazzes for the 5PZ Handbrake lever recall applies to most 04/mid 05 built. 11500 affected units.
I heard that from news in HK. Jazz and city recall
http://money.cnn.com/2010/01/29/news...dex.htm?hpt=T1
door water leaking, causing electrical false and fire. One people dead because of the fire.
Wheel bearings fixed as well ????
If there is a recall job that we miss. Are we still eligible to do it for free?
mine one has the door water leaking issue too.... when i had my rear repaired last time due to accident, the smash repair guy did tell me that, this is common problem for jazz.... 8 out of 10 of his repaired jazz had this problem.
which one you miss? i have done the fuel pump and the handbrake...
i did miss the fuel pump last time when i was in brisbane, then after i moved down to sydney, i just called up the nearest honda and gave them my VIN number. They will then booked you in for the recall.
when it is actually official. it will be listed on recalls.gov.au and Honda will literally give you letter of the warning.
that fuel pump relay, not all jazz affected, mine wasnt one of them. only the handbrake issue.
click this link
guys
dont panic..the recall is only for LHD jazz...not for our RHD Jazz : )
