All those who have an Euro, do you find that your right windscreen washer spray is spraying lower than the left side?
err, get a needle and stick it in the hole and move it to a position that suits you.
Can you do that for height adjustment? I thought it only works for horizontal adjustment.
As long as the spray hits the wiper blade, it is correct. Already asked this to the dealer at first service and they say all euro is like that (they claimed they compared it with all other euros they have).
I see. My right one is spraying about 20cm lower than the left side. The left side hits the top 1/3 of the screen, while the right side hits the bottom 1/3. I thought this was too big a difference.
these are the big issues :)
Definately :rolleyes:Quote:
Originally Posted by PERTH_EURO
Crap, I think my HID washer is spraying 0.05nm too high, causing my lovely black and shiny bonnet spoiled with water droplets. What should I do??
The sprays are meant to work best when the car is in motion.... the mist actually spreads better ...
Yep, I tried it once when stationary and it didn't work so good. Hardly any water got on the windscreen.Quote:
Originally Posted by EuroAccord13
so far I've sprayed when the car was at 60km/h. I'll try at 100km/h this weekend on the way to Canberra to see how it goes. Thanks guys!
spraying is fine, just the wiper is too fast sometimes, so it clears most of the water away, but leaves streaks around, or when headlights are on, a bit of water on the bonnet, and at faster speeds, it flicks off onto the windscreen :b
such dramas :b
hahaha I shouldnt have taken the piss earlier in this thread.... my Headlight washers aren't workin at all now... oooops
Hhehehe, just got back from Canberra. At 110km/h, the washer sprays fine. Thank you all for your advice!
Do the headlight washers turn on automatically with the windscreen ones?
not sure if mine work LOL
