CAM install gone bad. Help with rocker assembly.
Ive posted this another forum but imnot having much luck. Need help from the experienced peeps.
Ok guys, here is what happened. In short i installed the new Zex 59300 (my first time) and i ****ed up because i didnt loosing the lash on the rocker clearance before bolting down the rocker assembly again. Alas i cracked and destroyed my old 1! Now i am trying to source another assembly for my d16y1 and i have got a mate who had a complete y8 head - which i took the assembly off. Basically i posted this on another forum and was told it would be an OK swap as the VTEC assemblys are the same, but was then told that it wouldnt work at all, and the rocker arms are totally different. Seeing as though i could get my hands on it and use it if i needed, i grabbed the y8 assembly anyways and test fitted it up. i firstly tested fitting my y1 assembly to the y8 head, and then the y8 assembly to the y1 head.
The rocker arms look like they are fine to me in comparison with the old ones, and like up perfectly with the guides.. the only real difference i could see were a couple of moulding shapes on the allominium and the LMA up top. I finger tightend all the bolts and what i ended up with is as follows. My concerns are:
1) the valve lash clearance. i have pictured below 2 lash's are completly backed out and currently have almost 0 room to more before they put pressure on the springs. ATM the head is at TDC. Is this normal? The cam is a Stage 2 Zex (59300). i know u have to rotate the engine to set the lash correctly, but i am not sure if this is ok to torque down if they are already touching! because i ****ed up my old assembly like this last time (accept i didnt ajust any lash and just torqued it down - new cam remmber - and the pressure on the rockers crasked the asembly. OPINIONS?? this is my main concern!!
2) lost motion assembly. this is the main function difference i can see. the old ones in my y1 head did not have the retaining housing that these do.
Basically i need opinions before i torque these down, please help!
http://users.bigpond.net.au/weq/old1.jpg
OLD
VS
NEW
http://users.bigpond.net.au/weq/all.jpg
http://users.bigpond.net.au/weq/oilsquit.jpg
Oil squiters. noticly different housing, although actuating the same way
http://users.bigpond.net.au/weq/clearance.jpg
This is the clearance issue i was talking about. is it normal to have pressure on the valve when torqing the assembly down - it will ass about 1mm worth of pressure before its secure.
http://users.bigpond.net.au/weq/clearance3.jpg
Gap left before flush. Its finger tight atm.
http://users.bigpond.net.au/weq/dizzy.jpg
Im keeping an eye on this gap. if it doesnt close up when torqued, i wont use it
Can anyone see why this wont work? thoughts on the clearance issue? adivce in general? I am awaiting replys before i torque everything down and test out how the engine spins by turning the crank and and adjusting the valves. Is there supposed to be pressure on the valves when bolting the assembly down (i would think so?? cam lobes??)
Thanks heeps guys!
