Hi everyone, just thought it might be interesting to see if there is a pattern to this "pinging" issue in the new CU2 Accord Euro. Please keep your post to a bare minimum in this format:
Build date: xxx-xx
Break-in style: xxxxxx
Build date: xxx-xx
Pinging: YES
Build Date: 06/2008
Mileage: 1055 kms
Auto/Manual: AT
Petrol RON: 98 RON (except from dealer)
Style: ~70% easy driving and ~30% pushing hard
build date: Aug 08
mileage: 650km
style: trying very hard to keep the revs under 3k, more recently have ventured into the 3.5k zone
pinging: none....yet
transmission: Auto
petrol: 98 except for the first batch of petrol from dealer...pretty sure that wouldn't have been 98
Please keep this to a standard format so that it is clear. Do not add other text or asking to test drive other ppl's car. It makes the thread cluttered. This thread is ONLY FOR DATA COLLECTION. Use the CU2 pinging thread if you want to organise test drives.
Pinging: YES/NO
Build Date:
Mileage:
Auto/Manual:
Petrol RON:
Style:
Pinging: NO
Build Date: 12/2008
Mileage: 8600 kms
Auto/Manual: Auto
Petrol RON: BP Ultimate 98
Style: Smooth ;)
Pinging: NO
Build Date: 08/2008
Mileage: 590 kms
Auto/Manual: Auto
Petrol RON: 98 RON
Style: Granny style + a bit of accel now
Pinging: NO
Build Date: 08/2008
Mileage: 3500km
Auto/Manual: Auto
Petrol RON: 98 RON Shell VPower
Style: drove from Sydney to Tamworth first day.
Pinging: YES
Build Date: May 08
Mileage:4000km
Auto/Manual: Auto
Petrol RON: 98 always!
Style:Ping during slow acceleration in between 2-3k rpm before gear shift
Pinging: NO
Build Date: 05/2008
Mileage: 15,000km
Auto/Manual: Manual
Petrol RON: 98 RON BP Ultimate
Break in style: Drove it home ~500kms, then gave it a good flogging for a few days in a row.
Pinging: NO
Build Date: Nov 08
Mileage: 2,200 k's
Auto/Manual: Manual
Petrol RON: 98 Ron
Style: Didn't take it over 3,000rpm for first 800 k's
Pinging: NO
Build Date: 01/2009
Mileage: ~1400km
Auto/Manual: Auto
Petrol RON: BP Ultimate 98 RON
Style: Normal with occasional push to S and allowing the revs to hit 5k.
Pinging: NO
Build Date: 07/2008
Milage: ~ 4,500km
Auto/Manual: Auto
Petrol: Caltex 95RON
Style: Mostly Country B roads with occasional 6000+RPM
Pinging: YES (Pinging occurs frequently after 3000rpm)
Build Date: 08/2008
Milage: ~ 7,800km
Auto/Manual: Manual
Petrol: BP 98RON ALWAYS
Style: Mostly city/suburb driving and occasional highway and mountain (580m sealevel)
Pinging: Yes (mainly between 2-3k rpm)
Build Date: JUN/2008
Milage: 1,040km
Auto/Manual: Auto
Petrol: 98RON
Style: Varied
Pinging: Yes 2-3K rev range (Typically under load- eg uphill or AC on)
Build date: 11/2008
Milage: 3,000km
Auto/Manual: Auto
Petrol: 98 RON Mobil
Style: City driving
Pinging: YES
Build Date: 05/2008
Mileage: 6500 kms
Auto/Manual: Auto
Petrol RON: 98, BP Ultimate or Shell Vpower
Style: Smooth + a bit accel
Pinging: YES
Build Date: 05/2008
Mileage: 11000 kms
Auto/Manual: Auto
Petrol RON: 98, vortex 98 or BP Ultimate
Style: cruising, dont drive it that hard
Pinging: NO
Build Date: July 2008
Mileage: 8500km
Auto/Manual: Auto
Petrol RON: 95 with occaisional 98
Run in Style: Basically got and drove it like I drive my V8. A good mix of light and heavy throttle
Pinging: YES
Build Date:June 2008
Mileage:9558km
Auto/Manual:Atuo
Petrol RON:BP Ulitmate
Style:Normal
I know that this thread is for data purposes and the mods can feel free to delete this post but I thought I would throw something up for you all to think about.
I am not a mechanical engineer or engineer of any sort, so don't shoot me down, but this is just a thought;
A conventional gasoline engine usually has say a alloy head and cast iron exhaust manifold that is sometimes connected flush to the heat without a gasket, sometimes with a gasket in between, no doubt these two have different properties in the way they are made up and in there molecule structure and have different heating/cooling characteristics....
I was informed that the head and the exhaust manifold are actually one piece on these motors now, despite being a carry over from the previous model.
The point I am trying to get to is, could it be possible that as it is ALL the same piece of alloy, could some of the heat that is meant to exit through the exhaust system be transferred back into the area of the head around the cylinder chamber and be causing the pre-ignition? I remember years ago coming across a crysler/mitsubishi motor that would develop a hot spot in the head and this would cause pre-ignition and even running on to an extend.
Again, I could be completely off track here, but these engines have that many sensors that if it had been a computer/software problem surely it would be able to rectify it....
Let me just say that all 2006 on FD1 & FD2 Civics have the Exhaust Manifold cast into to Cyl Head the same as the the current K24Z3 in the CU2, yet no such problems exist in the Civic. Mind you, they do not run 11:1 compression ratio.
Post combustion ignition within the Exhaust manifold is nothing new. There have been several model cars over the years that have had this problem occurring.
In my belief if this was the actual problem All K24Z3 engines would be effected, not just a few which is the case. I could use the same argument & suggest that if it was an actual pinging problem in theory it would be more pronounced on vehicles with a manual transmission as owners would tend to labour the engine more (not downshifting soon enough) which would place more load on the engine, subsequently increasing the chance of pinging. Pre Ignition has usually been associated with high load / low RPM.
I still believe it is a problem associated with the timing chain / tensioner, but again if this was the case one has to ask why Manual Transmission vehicles don't appear to be effected? Could it possibly be something within the Torque Converter or an Auto Trans problem?
All we can do is wait for Honda HQ to find the problem so that effected vehicles can be rectified.
I have no such problem in my CU2 Auto, & 2 others that I know of personally are not effected either. It will be interesting to find out what the problem is eventually.
Pinging: YES
Build Date: Jun 08
Compliance: Feb 09
Mileage: 1600
Auto/Manual: Manual
Petrol RON: 95 to 98
Style: Everyday car, mostly city driving with occasional freeway run.
Pinging: YES. Entire rev range worst above 2000rpmish
Build Date: earlyish
Compliance: Jul 08
Mileage: 29000km
Auto/Manual: auto
Petrol RON: shell v-power
Style: Everyday car, rural roads
Pinging: YES
Build Date: Nov/08
Mileage: 2000km
Auto/Manual: auto
Petrol RON: Caltex 95ron only
Style: smooth
Pinging: YES
Build Date: Jan/09
Mileage: 8000km
Auto/Manual: auto
Petrol RON: Shell E10 or Mobil 6000
Style: average
Pinging: YES
Build Date: APR/09
Mileage: 5000km
Auto/Manual: Manual
Petrol RON: Shell V-power only
Style: Average
Pinging: yes but no more
Built date: 8/2008
mileage:20000+
transmission: auto
petrol: shell Vpower
style: normal with alittle bit push
Pinging: Yes
Built date: 07/2009
mileage:1600
transmission: auto
petrol: BP Ultimate
style: average
I have had a number of discussions with Fair trading in NSW, it seems that whilst everyone here is happy to have a whinge and wait, no one is willing to step up to the plate.
Fair Trading require anyone that has this problem to report it, so that they can exert some pressure.
If you are serious about getting your car fixed, take the right steps!
I did read the other thread, and yes a number of people have had "the fix", but a number of those people still report the problem occuring.
Putting it simply, in my eye's unless the problem is completely rectified, it is still a problem...
It is unacceptable that we pay $$$ and get treated the way we do.
As I mentioned in my post, I have had numerous conversations with a representative from Fair Trading, they are reluctant to take it on with only one formal complaint recorded.
We have 50+ pages on here of people complaining about the problem, and to report it to fair trading is just a matter of filing out a online form, it doesn't even cost you anything to do.
All they will do is to set a due date for honda to come up with an "update" status of this issue. This will still continue fo a while but the diff is that honda will have to report the stAtus to the fair trading. Note that they cant or wont make honda somehow magically fix the problem straight away.
Ps: i've said this bcoz it happens to my workplace before. We have report a problem woth our one of our supplier 2 yrs ago. But till todAy it hasnt been resolved.
this pinging noise, Honda refers it as "pre-combustion noise", caused by over sensitive knock sensor
Most people who drive their Euros hard will hardly get this problem compared to the ones who drive it softly.
If you go to Honda now, they will replace your knock sensor and intake manifold gaskets. that will solve the problem.
Pinging: Pinging like a rock band
Build Date: 09/2008
Mileage: 22,000 kms
Auto/Manual: AT
Style: ~90% easy driving and ~10% pushing hard
I'm sick to death dealing with the Brisbane dealer here..The dealer I bought with (near a major highway) completely ignore my concern..complain to HA, no reply..went to a different service dept near city, and they say they will get me a knock sensor but have to wait..
Its ashame the experienceI have dealing with Honda after owning several Honda for the last 2 decade...Sad to say this is my last Honda for sure..never buy another 1 again.
