As title said guys, since im having trouble to do so.
thank youuu
thank youuu
1- get under the car, there are probably 3 screws left right and centre, unscrew those
2- where eth bumper meets the fender, and in the wheel arch, it is probably screwd with a nut or a cross head there on each side, undo those,
3- lift up the bonnet and there shuold be around 5 screws, probably cross heads
presto!
hope it helps,
off the top of my head too and according to what i think will be logical
thanks :D but dont i needto take out the panel filler right above the bumper? i heard the screws for that is under the headlights, and one of the headlight's screw is just under the panel. LOL do you have any pictures?
You dont need to take out the panel filler, that was a mistake I made and it took way longer than it needed.
You need to look for 4 bolts, 2 on the left, 2 on the right.
Sit infront of your car and look/reach through the mouth part of the front bumper.
You will find them there.
They are the only 4 bolts you need to undo as it will allow you to remove the whole front bumper. Dont forget to remove the screws on the insides of the wheel arch :)
Best of luck :D
If it's anything like a EG, you have to take the splash guards off each wheel arch and it should be 10mm nuts. then 5 phillips heads between the headlights, and 3 10mm nuts under the bar.
hmmm yeah i know about the EG one, EG ones are easy lol, i just dont know hot to take the front ED bumper lol
thanks heaps anyway guys :D
didn't u do it back then?
snapped ur panel in the inner side if u didnt know lol
Did you read what I said? Because it's the way to do it.
maybe they dont want to do it your way,
there really isnt any other way to do it...
Lol i got it, took it out :D thanks heaps henessaayyy :D though it wud be easier with pictures but its alright i coped with it :D
Did you do it the way I said?
It's difficult to explain it in words, but I hope you ended up finding it all.
yeah i did, took me a while lol. WIth the help of my brother, he was able to figure things out detailed-ly. but also with ur help, i got to know where about the screws, this and that are. Thanks heaps
Awesome :) Not too hard, is it :)
Bah, if you were local (which you probably are) I coulda given you a hand.
PS, would appreciate + Rep ;)
LOL not really :L my bro did most of the stuff, i just showed him the comment you gave me here and he was like * lost face * and he went downstairs with me and just mucked around with the bumper and eventually he got it off haha thanks
Rep given :)
Haha, damn, was hoping i was more helpful than that :P
dw you are ;)
