Thinking of getting toda headers and a fujitsubo exhauast either
rmo1a or powergetter..
Has anyone had these done before?
how much? where? Worth it? any good deals?
Im abit weary, seen some pretty dodgy work done before.
its good. Popular combo, and all bolts on (bear in mind youll lose a cat)
Cat equals emission fail.
Real science proves global warming isnt the cause of carbon gases.
Natural occurance. Happend before =]
Cant really believe science. If you want powahh then go no cat! meaow =]
dont flame.. I dont really care about science.
For Toda Headers (Maybe all JDM headers??) on a DC5R, i'm pretty sure you need to change your front sway bar to an EP3R sway bar.
anyone got prices on these mods please?
1,100 dude.. i think.
But theres no other way to tell unless they put your car up on the hoist and do a emissions test.
Or they tap your cat and see if its hollow.
Most cases they wont even be able to put anything under the car if its been lowered.
Solution is put a silencer. And dont be a fully hektik bro.
okay. Anyone reccomend a good place to install?
was gonna go check out bel garage to see what they can do.
any other places? thanks heaps.
Toda headers. = Go to toda.
Only makes sense.
PM sent.
Fujitsubo in stock here
On spot fine is 20k if you running no cat......
You do realise you are allowed to get an aftermarket exhaust cut and welded to fit a cat...
contact adrian @ toda for your headers quality stuff
which will include headers + cat + ep3 sway bars + heat shield and all that, fitting, dyno before and after runs.
and contact yonas @ jdm yard for your fujit cat-back + injen cai! cant go wrong here, you will pull some good numbers high 13's with good driving.
and you may want to upgrade your clutch while your at it, it will be worth it for the long run.
Just recently switched from a fujitsubo powergetter to a buddy club spec 3 pro.
The make of the fuji is undeniable. It's beautifully made to match the beautiful sound.
But that sound is pretty quiet. Not much louder than the stock exhaust at all.
