has anyone here got any tips for a first time welder?
i've got an arc welder at home and would like to know any tips you guys might have.
Job: about 2-3mm steel [exhaust pipes]
thanks!
thanks!
Do a tafe course. :thumbsup:
I'm planning to do a tafe course in the next few weeks, I agree with the above.
Danny, if you need something welded a mate of mine is a boiler maker by trade and could do it for you.
Send me a Pm if you want him to do it for ya (won't want much, maybe chuck him a few bucks or a beer or something?)
Good luck....
Stick welding exhaust pipes would suck & propably end up looking like shit.
(Especially if done by a 1st timer)
Better off using a MIG or TIG...
If you're going to persist...
Get a really good welding helmet so you don't get flashed,
& practice heaps on stuff you don't need before you cost yourself more than you would if you pay someone else to do the job...
& if the parts are attached to the car...
Ge a surge protector or remove the ECU
Get some scrap and practice, a lot. I would suggest not even thinking about arc welding with the parts still atttached to the car.
i wouldnt arc weld an exhaust mate
i just did my block of it for my apprenticeship (fitting and turning) and trust me its not as easy as it looks, welds can be neat but take alot of time and a steady hand,
I did about 8 hours of it and was getting the hang of it, started with weld beads, then pads of weld, then building it up, then i did a T fillet, corner and lap joints and finally a butt weld
IHMO as the boys said do a tafe course, but if i were you money would be more wisely spent on someone doing it for you
As has been said above, ARC welding (unless it is shielded arc) is best left for heavy construction,or out door work where it is not practical to use MIG or TIG.
Most exhaust tubing should be about 1.6mm thick mild steel, so even an experienced stick welder will struggle to keep the weld pool under control.
yeah i was just practicing some weld beads earlier...wasnt too bad.
My bpipe etc are off the car just need to cut and joint a few spots for the install. Basically i cant get my hands on a cig or tig welder. I'm willing to pay for an exhaust shop to do it but i want to learn it for myself.
Also not too fussed on the weld spots being neat. Just scared of putting holes in the pipe lol. although i tried hard to put a hole in some random 3mm thick steal and couldnt do it? is it easy to put a hole in it?
thanks everyone
how long does the course go for?
It can be done, but 'arc' isn't the technique of choice for such thin steel (especially plated, which tends to cause the stick to 'stick' to the job). MIG,TIG or oxy-acetyline would be far easier and likely to give better results.
To do it with an arc / stick welder you will need to more or less do it as a series of 'spot' welds, each 'spot' overlapping the last. To do this successfully takes patience since after each 'spot' you need to stop and wait for the metal to cool off enough that the next 'spot' doesn't blow a hole.
Oh, and the metal will need to be clean...
correct and correct.
i was laughing, till i read this. no one even told him stick welding a exhaust was stupid.
as they said do a tafe course. if you know any boiler makers they can usally have it done in like 10 minutes, if its just a cannon being welded on.
not easy stuff. i did a radiator support once and holy shit that was a disaster.
i might hi-jack this thread a little... TIG or MIG when spot welding a chassis? seems like its a personal preference for most welders...
MIG will do a better job of burning through the crap that hides in the seams. So I use MIG for seam welding jobs.
Not 'real' spot welds (as you find in car body seams, made with a resistance welder), but each 'spot' being a very short arc 'run'. These 'runs' are so short that each one looks like a small circle, and each circle overlaps the previous circle, forming a chain of overlapping circles. When done well the overall weld can look very nice, but it's slow to do and can end up looking messy if you rush it or lack the knack.
The reason to do overlapping 'spots' is that between doing each 'spot' you can stop to allow the heat from the last 'spot' to conduct away from the weld site into the rest of the sheet / tube (where it dissipates).
A few things:
Aquire the knack of not letting it stick (which is a 'touch' thing that I'm still trying to properly master after 30 years).
Get the amperage right.
Make sure the steel is clean.
Grind / sand off the zinc plating where you are going to weld (this will also most probably result in a better weld with less porosity).
Use a stick / rod that tends to 'stick' less than other rods. I would suggest the 'Satincraft' rods (and similar from other manufacturers) as an easy(er) to use rod that gives good looking and ductile welds.
Some rods are harder to use / strike arc with than other rods, but give welds of a specific strength qualty. 'Easy to use' rods (such as 'Satincraft' and similar) tend to give softer welds that are less suitable for high structural loadings (you wouldn't build a boiler or a train undercarriage etc with them), but if you were forced to arc weld an exhaust would probably be the (type of) rod of choice.
Practice, practice....practice...............
For welding thin steel use a thin rod (I think 2.5mm is the smallest diamater).
My experience is that one of the hardest things when learning to arc weld is learning how to look through the arc and at the weld puddle (instead of looking at the arc). Once you get this it becomes a lot easier.
thanks for all the tips and comments people.
I've decided not to tackle my exhaust yet, but will be spending alot of time just practicing with random think and thin materials and see how i go.
My understanding is that it's OK to arc weld a chassis so long as the battery has been isolated (disconnect the earth terminal), and I've done it numerous times with no problems. This is no guarantee that the electronics will never ever get fried...
