Anyone know part number of the gasket that seals the rear taillight to the chassis?
pretty sure if you still have warranty honda will fix it for you..
just search up hey theres alot of threads an many ppls experience abt this issue!
rick
Tried calling up honda and they couldnt find it on the system but I did search for the gasket on clubrsx as you suggested and found the part no. its 33502-S6M-A11 for future reference. :thumbsup:
Thanks!
Shoulda mentioned the above part no is for 02-04 for 05-06 models its different....
05-06 taillight gasket: part no# 33502-S6M-A51
02-04 tailight gasket: part no# 33502-S6M-A11
glad it worked out for you man!
the gaskets are at around ~30 dollars each. and here is a good DIY for other ppl
http://forums.clubrsx.com/showthread...illight+gasket
so does this gasket work on 05-06 type S tail lights??
Same procedure but the gasket mentioned in that thread is the wrong part no. Im currently waiting for price from one of the ozhonda forum traders for the 05-06 parts.
i've got a bit of moisture in my type s 05 taillgiht s(left), ureckon if ijsut tell honda, they'll fix it ?
Yeah if you're still under warranty.
Same problem here, got my rear left tail light replaced under warranty last month.
The service rep told me they've replaced a few on type s already. It could be manufacturer defect.
not just type S, its just dc5's in general. if you have a water leak then get it fixed under warranty, otherwise you have to pay around $90 for labour + $30 for the gasket seal. alternatively just pay 30 and DIY
Yep better get in quick, I would imagine only the 06 models of the DC5's would be under warranty now with the 3 years.
quick question is this a roadworthy issue/defect?
