I want to sound deaden my doors on my ek hatch. So i was wondering if anyone knew where i could get Dynamat or Stinger Roadkil from & what it costs.
Ive tried Google but i cant find anyone that sells the stuff.
Where are you based?
There are quite a few businesses that sell it here in Melbourne...
I'm more than happy to sell you Roadkill / G-Spot / Dynamat etc.
Email me if you like as I do special prices for my Oz Honda Forum buddies. :)
Which ones the cheapest?
How do u apply it to the surface u want to sound deaden?
I've got G-Spot in mine. :)
It's easy to apply, the sheets are stick on so you just peel and stick.
Sounds easy enough. Do u have to sound deaden the other side of the door as well. In other words the side behind the speaker?
Where abouts did you apply it Vic? What improvements did you have?
i purchased sound deadiner from Super cheap.... havent used it yet.
I am doing inside the doors, and under all the floor carpet, and up under the wheel arches. will kepp you posted.
It's better if you do sound deaden the outer skin as well because it will give you a more solid sound. Bass from the speakers will go into that back chamber anyway, so if it's not sound deadened it may rattle a fair bit.Quote:
I've just about done the whole car. It has helped heaps in reducing road noise and the sound is clearer. I don't get as many rattles, all the panels are pretty solid when you tap them.Quote:
So u dont need to heat it at all?
I had to read that quote 3 times to realise you asked a question in my quote... :lol:
Anyway, yes, for it to stick the best you peel off the protective film, stick it on the surface then heat it while pressing with a cloth or something to seal it firmly to the surface.
I have Stinger Roadkill...
Best investment EVER!
Just e-mail FHRX and he'll fix you up!
I did most of my passenger door last week using Flashtac. Unfortunately I ran out of the stuff and cfb continuing after I went and bought more.
A friend of mine took pics but she hasn't emailed them to me yet. I'll post them up once i get the pics.
You should put as much as you can afford. Budget about $100 for the two front doors.
Even a little bit is better than nothing at all. Infinantely better. Like this:
Something like this. :D
How much of a weight increase are we looking at ?!?!
hmmmm....this door looks familiar.....yeps definity my car :P
http://www.fastfoursforumscarclub.co...nterest_63.jpg
Weight increase depends on which sound deadener you use and how much you apply. For example, a box of Dynamat is from memory at least a few kg's. And that will probably just do the front doors.
I have only alittle bit more then the pic!
I wish i had money to get my boot done!
I'll get it done soon :D
Anyone got pics of their completed door?
Depends just how silly you want to go really.
Take this example, you take one door complete with badly fitted system:
http://www.fastfoursforumscarclub.com/temp/dead/1.jpg
Weave a little Fhrx Studio's magic on the inner skin:
http://www.fastfoursforumscarclub.com/temp/dead/2.jpg
Then finish the outer trim:
http://www.fastfoursforumscarclub.com/temp/dead/3.jpg
That one is using G-Spot Serenity Max. Here is another one using Stinger Road-kill:
http://www.fastfoursforumscarclub.co...nterest_45.jpg
OMG~! That's gonna cost heaps!
Is it okay to do just the outter skin?
How much does it usually cost for a professional job like that?
You're looking at about $110 for the deadening and around 2 hours at industry rates of $60.50 per hour. :D:D
http://members.optusnet.com.au/btn2000/Dynomatting.jpg
Dynomatting
From the foot well to roof to the boot, took 3 packs of 15sheets. 2 full complete days of heatgun, finger burning work :cry:
