Hi All,
If you have any questions regarding our products, please feel free to post them up here or you may PM me.
Thanks
Mfactory AU
Hi All,
Thanks
Mfactory AU
Do u have Front camber kit for DC2R?
how much for F20c 4.57 final drive shipped to Victoria 3083??
any updates with my order? cheers
e240,
i used your gearing calculator. and was wondering
- how come fd plays role in the rpm shift landing point?
- assuming the use of jdm k20 gearbox 6 speed
- red is using 4.7fd
- blue is using 5.4fd
which one would be accelerate faster?
http://i516.photobucket.com/albums/u...cheese/1-5.jpg
edit: thanks for sharing your info.
There is no oil cooler kit on the site and I pm'ed you about it a few weeks back with no response.
a little help please?
Oil Cooler - Sorry man, its all out of stock...I'm checking if new stock is coming in...
Hey Sorry for the late reply - I am soo slack..LOL..
1) going with a taller final drive gives you more torque by mechanical multiplication. The higher the ratio is, the easier it is for the drive axle to turn the wheels = faster acceleration. Your rpm shift points don't really change, but you'll find yourself shifting at a lower speed.
2) With a shorter final drive, you achieve a higher RPM @ a lower speed, the acceleration on the 5.4 would be faster
installation manual for short shifter? :) and how tight to hold things in place?
Its no different from installing a stock shifter. Nothing special and easy for DIY.
Just make sure when bolting the shifter to the rod, that the movements don't bind.
I ordered one of your LSD's through the website last Thursday, and i've been told its already arrived. Great stuff :)
Thank you!
PM sent! :)
possible to obtain the size of the rubber gasket for the sandwich plate? (or if you could send me out a few spares even :)?)
Hey,
I need some parts for my d16y4 build. Do toy guys have any of the following in stock? and what would you recommend, I'm located in Brisbane.
1) Main Bearings and Thrust Washers - Brand and where to buy.
2) High volume oil pump - brand and where to buy
3) Full rebuild gasket kit - What head gasket do you guys recommend running on a turbo'd d16y4 with decompressed pistons.
4) Good Quality Head studs - brand and where to buy (ARP?)
5) Good Quality Pressure plate to suit a turbo installation - Brand and where to buy.
Any help is greatly appreciated.
Regards,
George.
Hi George, wow. for your questions on engine builds, I strongly recommend you give Toda AU a buzz who's a trader on this Forum for Toda Performance.
As for the pump gear, I'd only recommend Toda.
Clutch - MFactory carries a couple of racing clutch options. These are currently used in a couple of IPRA (Improved Production Racing Australia) racing this season.
http://www.teammfactory.com/racing-clutch
Thanks e240 for all your help. I will be contacting Toda and Mfactory. =] Greatly appreciated.
hi there,
quick question regarding final drive gear for DC2 Integra. I noticed on the site there's an option for the 4.9 to have it in either B16B/B18C or B18C 98 spec.
wat is the difference between the two? i own a 96 VTi-R (Y80 i believe..) however im intending to install either ITR LSD or MFactory so which of the two final drive gears do i go for?
guidance would be appreciated =)
my civic is race more than street car, i am having trouble to get Torco and Amsoil transmission oil.Quote:
Street car/daily driver - honda mtf
street car/weekend warrior - honda mtf/torco mtf/amsoil mtf/pennzoil synchromesh
race car - torco mtf/amsoil mtf/pennzoil synchromesh
+ plate lsd - add ford friction modifier until the noise level becomes acceptable to you.
can you point out where i can get them in australia?
hey there,
thanks for that.
also is this the Ford Friction modifier i can use for my gearbox?
http://www.ebay.com/itm/FORD-XL3-FRI...81c395&vxp=mtr
or i can just go to Ford dealership and get some locally?
Since its more of a race car, I wouldn't bother with the Friction Modifier.
That is just there to control the noise and in doing so, slightly diminishes the grip.
Can anyone tell me if e240 is still trading?
I've been chatting offline with the guy but now I've transferred some money he's not responding... I'm hoping for a good outcome.
Never heard any bad story on here about him so dont stress yet
All good - contacted me.
I was peaking a little bit...
Could you please give me a price on a K-series helical LSD shipped to 3041, Vic?
Leonard I sent you an email did you get it?
Oh yes. Sorry I'll reply n the morning.
All good thanks
