Originally Posted by TODA AU
Bang for your bucks – DC5R mods
By request,
Bang for your buck – DC5R
As with DC2, The DC5 is pretty fussy when it comes to mods that actually work…
On the race track… The following parts are must haves…
Oil cooler / low temp thermo fan switch…
If you can’t afford a good aftermarket radiator, at least fit a low temp thermostat.
Both are better…. Suspension & brakes also need to be addressed.
These aught to be addressed before you chase any extra HP.
As for getting more power, Honda’s are pretty fussy…
The actual parts combination is everything…
It must be put together exactly right… I can’t stress enough how important this is.
Once it’s put together right, it can be tuned… This also should be spot on…
The three work together, if 1 side has a weakness, power suffers…
Examples: Your pipe dream combination isn’t right… Power suffers…
Your mechanic doesn’t really know what he’s doing… Power suffers…
Even with perfect combination & assembly, with crap tuning… Power suffers...
NB: When fitting a heavy duty clutch to a DC5R, the front and rear engine mounts should be attended to.
That is fill them with sikaflex or use Mugen inserts / mounts.
This will avoid the inevitable knocking on the floor under the driver of the exhaust system.
Minimum budget – Just a bit quicker…
#1 – Intake - Never use a SRI of any brand – CAI only (Eg: INJEN / AEM / GruppeM)
#2 – Header + S2000 cat + cat-back system (60mm minimum)
Power output: 116 ~118kw @ wheels (Dyno dynamics- shootout)
Low budget – Sleeper (Quiet & quick)
#1 – Lightweight flywheel
#2 – Heavy-duty clutch
#3 – Lower final drive
#4 – Modified stock airbox (Aka Hondata)
#5 – Header + cat + JDM DC5R or Mugen cat back
#6 – Hondata K100
Power output: 120 ~122kw @ wheels (Dyno dynamics- shootout)
Low budget – never going to get an ECU
#4 – Intake - CAI's deliver superior results.(Eg: INJEN / AEM / GruppeM)
#5 – Header + S2000 cat + cat-back system (60mm minimum)
#6 – Spec A2 camshafts / valve springs / head gasket 0.3mm
Power output: 126 ~128kw @ wheels (Dyno dynamics- shootout)
NB: Add K100 ECU for 144~146kw
Low / Med budget – Never going to crack the engine open.
#6 – ECU + Dyno tuning
Power output: 128 ~132kw @ wheels (Dyno dynamics- shootout)
Medium budget – Hate noise & Stop @ ECU
#2 – Heavy duty clutch
#4 – Intake – Modified stock / GruppeM or Pipe style CAI (NB: CAI loud @ WOT)
#5 – Stock exhaust system / or stock JDM DC5R exhaust system
#6 – Spec A2 camshafts / valve springs/ 0.3mm head gasket / ECU / dyno tuning / heavy duty engine mounts.
Power output: 136 ~138kw @ wheels (Dyno dynamics – shootout)
8600rpm rev limit
Medium budget – Stop @ ECU
#4 – Intake – CAI's deliver superior results.
#6 – Spec A2 camshafts / valve springs/ 0.3mm head gasket (Compression up from 11.0:1 to 11.4:1 / Titanium retainers / ported head / JDM intake manifold / ECU / dyno tuning / heavy duty engine mounts.
Power output: 148 ~150kw @ wheels (Dyno dynamics – shootout)
9000rpm rev limit
High budget – best power delivery
#4 – JDM Intake manifold + CAI only
#6 – Ported head / Spec A2/B/C camshafts / valve springs/ Titanium retainers / adjustable cam gear - exhaust only / fuel pump / Forged pistons / Forged rods (For over 9000rpm) / injectors & fuel pressure regulator / ECU / dyno tuning / heavy duty engine mounts.
Nb: Additional head work that can/may need to be done includes shaving of rocker arms for cam clearance, re-shaping of valves, combustion chamber re-profiling.
Power output: 156+kw @ wheels (Dyno dynamics – shootout)
Products soon to be released...
- TODA Racing K20A 2.2L stroker kit
- TODA Racing K20A quad throttle sports injection
- TODA Racing K20A iVtec "Race" camshafts
- TODA Racing DC5R cat-back exhaust systems (Available now)
Race engine (Drag / Improved production car or better)
#1 – Lightweight flywheel (Consider twin plate / carbon )
#3 – Lower final drive / transmission cross gear kit
#4 – Quad throttle sports injection + fabricated CAI duct / flue
#5 – Header + cat-back system
#6 – Ported head / Spec A2/B/C camshafts / valve springs/ Titanium retainers / adjustable cam gear - exhaust only / fuel pump / Forged pistons / Forged rods (For over 9000rpm) / injectors & fuel pressure regulator / ECU / dyno tuning / heavy duty engine mounts / baffled sump.
Power output: 165+kw @ wheels (Dyno dynamics – shootout)
Race engine – GTP production car (stock)
#1 – JDM flywheel & Exedy HD clutch
#2 – JDM exhaust manifold
#3 – JDM intake manifold
#4 – SPL (open) exhaust system
#5 – Std intake / stock air box – no modification permitted.
#6 – ECU / extensive dyno tuning / heavy duty engine mounts / baffled sump.
Power output: 120~122kw @ wheels (Dyno dynamics – shootout)
DC5 Base model – low budget
#3 – DC5R Gearbox & Lower final drive
NB: DC5R cat back can be used on base model with small mod to rear or base model cat.
Further modifying the airbox – Hondata style also adds a little power…
For those who aren't sure, automatic models do not have flywheels or clutches
Regarding modifying your car.
If you can’t afford to do it the right way, avoid the temptation to do something right now & save up until you can afford to get the right parts.
Obviously I recommend using only TODA products where they exist for the application.
Products from other manufacturers can be substituted with varying levels of effectiveness.
Ok… as before… Comment away...
Cheers
Adrian
TODA Racing Australia
