Originally Posted by
Chr1s
I think there is a little more than just a quick slap together than most of you are mentioning.
There is a lack of a few things from a quick browse of the thread, a tune, a chipped ecu, new clutch, machining work, head servicing if need be, gasket kit, fluids, misc work for install, breather setup, etc
What is with the internet nowdays and talk of rod ratios? I always see this come up. Yes it matters, are we circuit racing? no, is it going to make much of a difference if you drive like you should and maintain your car? no. When your building a motor with high goals for power, then come talk about rod ratio's and its effect on engine longevity and power.
Piston squirters - I dont run them, I don't see a point unless the car is seeing extended RPM's for a long time. Even then, in a motor with that purpose, it will have forged pistons which can handle the heat and abuses of such work.
I think best option is find a B18 and rebuild the bottom to freshen it up.
