Hi, I thinking to lower my ride and dunno wather to get Eibach PRO-KIT springs or Tein S. tech. I am mainly after looks. Whichever is better?
which ever one lowers it to the ride height u want i would say.
http://www.ozhonda.com/forum/showthread.php?t=126106
check out my thread, im gonna be moving onto coilovers soon, if ur interested in the ride height, lmk, i can sell this setup to u pretty cheap.
reason im going to coilovers is this is too low for me
wat springs are they?
Just for looks?
Just get king springs. Lol.
I've heard alot of good things from teh eibach tho!
whichever best working with oem shocks?
Eibach Pro Kit are excellent springs. Though may be a bit much $$$ wise if all you're after is cosmetics?
You can just get pedders shocks+spring combo
pretty good from what I heard.
just an fyi, the eibach pro kit spring rates for ek are progressive 290/190lbs(5.17/3.4kg) front and rear respectively so they are not a hard spring
stock seems to be about the 185/80lbs mark
can't really go wrong with either spring, comes down to what height you want and which one will achieve that result
no idea on spings they r, i had a look when the wheels came off, but couldnt make out any markings, ill prob know more when they come off
Get Koni shocks ground control kit and you will go low
COOL, im probably getting a set of pro kit soon.
Pro kit were low as well prob on par with wat I'm running maybe a little higher
im getting my adjustable damper koni shocks with eibach pro kit install on my car soon, good combo?
Great combo. Will handle well and retain very standard-like ride.
