So ive been looking at cusco bolt in roll cage for my dc2
but ive noticed that it says its not available for sunroof.
is there any bolt in roll cages available that are compatable with sunroof?
preferebly 5-6point
anybody?
thanks
preferebly 5-6point
anybody?
thanks
anybody?
give it a day or 2 sum1 is bound to know
Doubtful, since the bolt-in cages require you to rip off the roof-lining, so that probably means you'd need to rip out the sunroof mechanism otherwise it would get in the way.
I would get in touch with 'Bond Roll Bars'
have a cage in my little crx, didn't have to remove anything but rear speakers
Are you after a fullcage or a halfcage?
I run a halfcage and im pretty sure it wouldnt require you to remove your sunroof.
Im not 100% sure on this since I dont have a SUNROOF, but my rollcage stops just before the interior light so..
I can take photos if you want.
yer photos would be great thanks
getting serious race spec now mike, lol
BOLT in.
I bought it from a mate of mine;
Haven't seen anyone else with the same cage
These photos are from 08, my boot is completely empty since then.
http://xntrik.com.au/images/21.jpg
http://xntrik.com.au/images/22.jpg
http://xntrik.com.au/images/23.jpg
You can see the clearance from the interior light,
But since I don't have a sunroof, you can estimate from there.
No worries. :)
its a real shame you have to strip the back on the car to fit the cage.
I had a custom 1/2 cage, retained my interior + roof lining and sun roof.
One thing to note is that the cusco cage are not CAMS approved, so you cannot get it logged and approved for competition.
I would rather buy a bonds bolt in cage as oppose to cusco.
whys that speedcore??
The diagonal needs to be on the side of the driver's head to reinforce that point in the event of a roll over. It the even of a rally car or 2 seater, you have 2 diagonals.
That picture probably has the cage for a left hand drive car.
yep, would have to be designed for a LHD drive car. still looks awesome :thumbsup:
anyone with a rear half cage in an EG Civic?
love your cage and seats :P
ef civic should have pics, he has jamies old EG
Yes my diagonal is in the wrong position,
I've been meaning to get another one welded for awhile now, just been spending money else where atm.
for reference,
Its a bonds rollcage.
Nice welded rollcage btw.
Works much better.
:thumbsup:
:thumbsup:
hmm i dont think this is the case.. Bonds Cages that have one diagonal start at the top of passenger side, and meets at bottom of driver side. Bonds Cages are all CAMS Approved
Went back and read ROPS again....
Indeed it does not seem to state above "drivers head". So I will retract my statement about it.Quote:
2.7 Diagonal member: Transverse tube between a top corner of the main roll bar or upper end of a backstay and a lower mounting point on the other side of the roll bar of backstay.
I will point out however that all diagrams except 253-3A, show a diagonal going to top RH side of main hoop.
Diagram "Type 2" depicting a half cage also has diagonal going to top RH side.
yeh the diagrams are just examples i guess.. but yeh. i actually spoke to the guy down at BONDS. i think his name was Alan ? anyway, this Bonds Cages dude said he designed them like that in event of a roll, the diagonal doesnt break and hit the drivers head. :/
they're not meant to break ? thats what we pay you for ! lol
So should I get that extra diagonal cross welded or not?
Lol, I was gonna get it done before mid year.
I always thought my diagonal was wrong.
get it for wank factor :)
Ye of little faith..:D
Schedule J:
3.2.4 Diagonal members: Each At least one diagonal member must be fitted. Its location must be in accordance with drawings 253-3 to 253-5 and it must be straight....
For FIA International events for Group N and A vehicles, any vehicle of a type homologated after 1 January 2002 the fitting of a second diagonal in the main hoop as per drawing 253-4 is mandatory. The junction of these two members must be reinforced by a pair of opposing gussets. Details are available from CAMS, or the.
-> So while not spelt out specifically, for CAMS homologation, you need to follow the basic drawings, and they all have the diagonal to the Driver's side.
For the specified Intl homologation, you need Two diagonals -
-> Prior to the 2009, the CAMS manual specifically state "For competitors without co-drivers, only one diagonal emember may be fitted but its front connection must be on the driver's side."
The current manual, by stating must be in accordance with drawings 253-3 to 253-5 makes the pre 2009 statement redundant.
because all the drawings bar one have the diagonal on the driver's side.
I'm reading the rules as they are....no more, no less...
Gentlemen,
The diagonal can be located to the top on the right or the left. It is not specific. YES, the drawings in the CAMS manual show it mainly to the top right, but that is merely artistic representation.
Think of the diagonal as the triangulation joint, and once the main hoop becomes 2 triangles it matters not where the corners are located nor where the loads come from, it will oppose the deformation in exactly the same way.
There is actualy more chance of the main hoop failing at the top right if the diagonal join is placed there. This is due to the HAZ (heat affected zone) either side of the weld.
Another point... CAMS do not specify the orientation of the diagonal in the main hoop or the backstays as they don't specify a difference between right or left hand drive vehicles. Left hand drive is perfectly OK as long as the vehicle has the correct homologation papers to support it.
What I see of a greater concern is the location of the lower mounting of the backstays. Specifically the fact that they land on a lateral member(strut brace) which, under deformation loads places this member in bending and worse still the mount on the rear shock housing in shear. All that is bad, very bad. The backstays should always land on a reinforcing plate and any other lateral beams or members should join there as a notched node.
Yes I build cages..........;)
