hey guys, i only have cai and cat-back and im running rich whyyy..
Honda tuned them that way. Lots of things that can effect the A/F ratio though. like O2 sensors, MAP sensor, fuel pump, injectors, grounds, ignition coil, spark plugs, etc.
ahh gay.
How do you know your running rich? What are the signs your seeing?
should have bought a integra
would be a nice trick to shoot flames but its all about the $$$$$ wont an ecu upgrade fix this?im sure it will, to change the fuel distribution once the engine gains all the extra cold air?
wat does running rich mean ?? never heard the phrase??
To burn petrol a certain amount of air is required (something like 14.7 parts air to 1 part petrol). When someone says they are running rich then that means they have more fuel than required. If someone says they are running lean, then there is more air than required.
Pretty common phrase though, especially on a car forum.
lol anyway, vafc should work huh
hm.. i dno never heard it.. lol never knew u could have 2 much air lol.
thanks.
Whoops.
