Anyone know the cause .. it started by turning on randomly .. then happend more often and now its permanatly on (except when cars off).
check the connector at the base of the handbrake, as it may have come loose over time.
i have the exact same problem in my prelude. but as well as handbreak it has the light saying my reverse light isnt working as well. its been like this for years ive just gotten used to it
also check your BRAKE FLUID LEVEL.
Mine came on my old car, when the rear car bulb blew
happened to me when i needed to change my brakes
also if ur fluid is black and has lost its viscosity as a fluid it may not read as havin fluid if the above ppl hav said does work
Turns out it was a combo of things .. low fluid level - didnt fix .. checked all fuses in car and engine bay .. turns out the ECU backup fuse was blown somehow ..
