step 1: obtain 1mm aluminium sheet (I got 90mm by 60mm)
step 2: obtain 20 x M3x20mm countersunk hex screws and 20 x M3 x 10mm button head hex screws
step 3: obtain 10mm x 10mm x 1000mm of aluminium angle
step 4: obtain some 6mm thick Perspex
step 5: obtain some seriously good double sided tape (I had some 3M stuff)
step 6: remove sunroof
http://i913.photobucket.com/albums/a...ve_sunroof.jpg
it weighs 15.3kg all up
http://i913.photobucket.com/albums/a...kg_sunroof.jpg
step 7: place aluminium sheet over sunroof hole and using a marker pen, trace an outline of the hole on the underside of the aluminium sheet
http://i913.photobucket.com/albums/a...nroof_plug.jpg
step 8: using a jigsaw, cut the aluminium sheet to size and dress edges (this takes a while to get perfect, I used a metal file and several grades of sandpaper)
step 9: cut aluminium angle into 10mm sections (called L-tabs):
[IMG]http://i913.photobucket.com/albums/a...ete/L_tabs.jpg[/IMG]
drill 3mm hole in each L-tab:
http://i913.photobucket.com/albums/a...led_L_tabs.jpg
line up the each L-tab with the groove around the sunroof hole, kinda where the spot welds are, and drill 3mm holes in the steel drapes around the sunroof hole, 5 on each side and 8 on the leading edge:
http://i913.photobucket.com/albums/a...lled_holes.jpg
install the L-tabs
http://i913.photobucket.com/albums/a...ed_L_tabs2.jpg
http://i913.photobucket.com/albums/a...ed_L_tabs3.jpg
cut up the Perspex into 10mm sections
http://i913.photobucket.com/albums/a...ex_spacers.jpg
and add the double sided tape
http://i913.photobucket.com/albums/a...x_spacers2.jpg
then add the Perspex spacers to each L-tab
http://i913.photobucket.com/albums/a...ed_perspex.jpg
trial fit the aluminium cut out, then shave edges to fit,
a maximum of 0.5mm gap should exist between the sunroof hole and the cut out.
then determine which L-tabs will need further vertical spacing and make up some aluminium spacers from the off cut aluminium and d/sided tape
http://i913.photobucket.com/albums/a...um_spacers.jpg
add the aluminium spacers
http://i913.photobucket.com/albums/a...ed_spacers.jpg
then drill from the top through the spacers into the L-tabs about 3-5mm in from the sunroof hole edge.
next, place the aluminium cut-out in the hole, put a object that weighs around 1.5kg on one side of the cut-out and align as well as you can, and from underneath drill one of the centre L-tabs on one side and install a screw. then check alignment and then when happy, drill the centre L-tab on the other side, install a screw and check alignment and when happy drill one of the centres L-tabs on the leading edge.
check alignment and when happy drill the other 15 holes.
http://i913.photobucket.com/albums/a...lled_plate.jpg
remove the cut-out and the countersink each hole to suit the screws.
in the rear edge, drill a set of holes (I used two, but might add some) so that when a screw and nut is installed the nut sits exactly the width of the aluminium cut-out below the top of the roof.
http://i913.photobucket.com/albums/a...rew_holder.jpg
http://i913.photobucket.com/albums/a...der_close2.jpg
http://i913.photobucket.com/albums/a...lder_close.jpg
[I might add to these, depending how well the vinyl holds the rear edge down]
tidy up all the swarf and install the cut-out
http://i913.photobucket.com/albums/a...ith_screws.jpg
http://i913.photobucket.com/albums/a...th_screws2.jpg
http://i913.photobucket.com/albums/a...lled_close.jpg
last step is not completed, but it is to add a vinyl sticker over the cut-out to make it waterproof... I have chosen a CF style print, but it could be body colour etc...
http://i913.photobucket.com/albums/a...e/cf_vinyl.jpg
as you can see the vinyl was damaged in transit, so still deciding what to do...
more to come....
