Does Ek4 brake pads fit EK1?
do any other pads from any other cars fit?
no ek4 calipers are larger than the ek1's(unless you're talking about facelift sedans)
thanks vinny!
so does the EK CXI/GLI pads interchange with any other hondas?
and are EK4, EK9, and DC2VTi-R calipers the same size?
ek4 and dc2 are
ek9 and dc2r are the same
not sure about the interchangeability of the ek1 pads, maybe eg's?
why even bother trying to find out whether you can get it from another car, just ask for pads for your year and model
I thought EK1 sedan front brake pads were the same as EK4 ?
yeah pretty sure he's got an ek1 hatch though
EK1 facelift and dc2 disc are the same but the calipers are not.
just curious really..
considering whether to get new pads or new calipers as well
yeah as long as you got the right size rotor and calipers/brackets too
which ek1 do u have? afaik cxi are different to the rest and are not compatible with gli pads
easiest way to find out wud be to go on the bendix website and see which models have the same part number
oh? so only same rotor size?
i know 96spec dc2r's front and rear pads were the same as ek4's
in regards to pads
Ek1 have their own
ek4 and dc4 are the same
vtir and 96spec jdm itr are the same
Imo best upgrde would be to get Ek4 hubs second hand with rotors and pads.
set u back around 300ish + labour. Much better braking than Ek1
also consider converting rear drum into disc.
dont forget to change booster + master, and prop valve
