just wondering if ne1 would no roughly the top speed of a ek hatch with a stock b18c?
same as it would be on the car that the b18c came out of. The top speed is limited/dictated by the ECU and mechanicals of the transmission ( IE gearing ) .
I thought most JDM performance cars (nissan, toyotas etc) were limited to 180-190km/h. so depends where the motor/ecu is from. Why? unless you are on a track only a fool would do speeds like that on the street
well i want to take it to track days but mainly just my daily driver so i wouldnt be gettin it that fast everyday
i got a b18c , untuned. hit limiter on my rsm - 177km/h
180 on cluster
im ganna guess 230ish (assuming its not a jdm b18c)
All imported jap cars should be limited to 180 ish k's considering that they are stock. If the issue is hitting top speed on the track the cheapest was is an apexi rsm. Which comes with a speed limit cut. They pretty cheap on eBay.
white_ep3_civic so speed limut cut means it will basically override the speed limiter??? all on the track of course and do u no if it is legal?
Yeh it is legal. Yep the rsm will just get rid of the speed limiter that the ecu has in place. Look for a wiring digram on google. It will show you what u need too do too cut the limiter
Wind resistance will play the biggest part. Unfortunately, even if he was in 5th gear, just at the point of peak torque and a bit below peak power, the car still won't accelerate more if the power being produced is not sufficient to overcome wind resistance.
and how much road you have lol
