You are "supposed to" lightly dampen the wrap while applying it as it get its to wrap tighter and set better.
A few things to know about the wrap. Obviously the degree it affects your headers is going to be based on a number of factors. Such as, Timing, AFR, type of metal used in the extractors, environmental conditions (humid, salty).
I am one of the cases that had this stuff totally rape the face off my extractors to the point that they look an aborted child's face after its been run over by a an industrial, diesel powered cheese grater.
you can kinda see a before in this shot. These are pacemaker extractors on my falcooooon. Pacemaker is a well respected brand for these cars.
Ignore the dodgy hot air intake, this is when i was running the cam it, did a quick dodgy up to get the run in done before fitting the aftermarket ECU.
http://i346.photobucket.com/albums/p...7/Image584.jpg
then my wrapping when i first done it (before i bolted back together)
http://i346.photobucket.com/albums/p...7/Image513.jpg
and about 2 months later i developed a hole in my extractors. which quickly worsened.
I pulled the wrap off to investigate.
http://i346.photobucket.com/albums/p...7/Image515.jpg
http://i346.photobucket.com/albums/p...7/Image516.jpg
as you can see the damage was not only local to the "hot spot"
I used the wrap to try and lower under bonnet temps. it worked well. However you get a hotspot at the end of the wrapping. which happened to be my collectors. Also you can see this accelerated rust scale from the metal breaking down is from the heat and ingress of moisture from the wrapping material.
This combined with my high exhaust temps due to far retarded ign.
There is no doubt in my mind that this was caused by the wrapping.
i blasted, weilded and painted the extractors but they are not what they used to be. And they still have a damn leak..... *RAGE* Basically i spent like $90 to have something waste 2 hours of my time, a gasket, some gasket goop and slowly destroy my headers. Thumbs up. *lame face*
Obviously it's not necessarily GOING to happen. But seriously... why risk it?
a better alternative is simply some alloy sheet bent up into a "heat shield" Effective and nil negative side effects.
Performance boost??? Unless you have a turbo the performance boost is negligible. a 300-600HP car may pick up 5HP from wrapped turned length exhaust on a NA car. Something i doubt you'll be able to "feel" other then placebo. An FI car will experience gain because it's the velocity and HEAT energy in the exhaust that drives the turbine. If you wrap the pipes between engine and turbine then you will get more heat energy into the turbo.
so, IMO, don't use heat wrap unless you got plenty of money to be wasting... ESPECIALLY at the price they charge for the shite!
That said and done, It was a good writeup!
