Hi guys,
i just want to know if a OEM Ek9 front strut will fit on my Ek1 civic straight bolt on???? dun wanna drill holes and that on my car.
Cheers
Hi guys,
Cheers
It is straight bolt on if the holes are already there..if not, you have to drill 2 holes on each side near suspension there but normally all the holes are already there.
LOUIS
JDM-Channel
Dimensions same ( same chassis ) but there isn't mounting bolts in place.
You must drill the 4 x holes then use 4 x bolts and 4 x nuts to secure the brace.
This brace , is exactly the same as dc2 vtir and ek4/em1 braces except red instead of black
I think you will find it's thicker because it is painted with crinkle style paint ( same as camcover) not because of it's material properties. Unless , you have stripped back the oem vtir and ek9 chassis braces , and measured the
thicknesses with a vernier caliper ?
ahh k i thought you could just nip the very out edge - this would still give an accurate result. Can you also weigh it too with kitchen scales or similar ?
will do if i can find one here. In the meantime , anyone got a OEM one lying around that can provide the above details for all of us ?
oem ek4
od; 25.5mm
id; 23.1mm
mount plate thickness; 2.3mm
measured with a digital veneer caliper, not a ruler/tape measure and eyeball
EK9 is made from different material meaning its more solid than the black EK ones .. compare the weight and see.
