im just about to get some sparco wheels. just need to know if they will fit my ek.
the wheels say A356 16x7JJ 35. they are 4x100. just need to know if i get rubber
for them will the rub on the guards etc.
Cheers
Cheers
Might be some rubbing, yeah. Especially if your car is dumped. I was previously running 7" rims with +43 and 215/40/17 - they rubbed a little on my EH Civic.
On my CRX I'm using 15x7 + 35 and they don't fit into the guards.
You might need to roll your guards and consider some camber. Also I wouldn't go wider than 205 on your tyre width.
so no with these then? my car is stock height atm.
Looks like you'll rub if you drop your car and have stock sussy. If you keep it high and have stiff springs you'll be fine.
Otherwise to be honest I think you should go for +45 when you're getting 7" wide rims, otherwise you need to roll your guards and maybe get camber which is too much fuss for me.
I'd personally rather stick to something 6.5" wide and minimum +35, preferably +40 or so. Stock Honda offset is +45 I think.
dude, they will fit no worries at all. do it. might scrub a little if you slam your car on the ground or something. just get 195's and you will be fine, even 205's.
And don't corner hard :(
they'll fit with no worries as others have said, and no scrubbing at all... i know cause im running similar offsets and size.... the front will sit perfectly flush, an the rear will tuck in a bit, typical... unless u want the really flush look, u gotta run lower offsets in the rear..... dont run spacers btw, illegal and not always guarantee safety thing.... If u do slam it, it will look wicked, an none of that pathetic tuck in look, but each to their own taste when it comes to wheel fitment...
maybe, the ef8 has smaller wheel archs? i dunno exactly but could be the chosen off set .... tire size, 205 side walls will sit flat... 195 will stretch slightly....
Ahh fe I thought u were saying something along the lines of flipping the car haha
stock height should be no problem ,if you lower your car then i think guards rolling should be enough imo
hi. looking at new shoes. rota flashbacks need info asap they are 15x7 et40 cheers
205 will fit flush.
Depends on what you want. If you want awesome dry-grip get something like Hankook Ventus RS2, Kumho KU36, Bridgestone Adrenaline Potenza RE001.
Also I've heard Toyo T1R's are excellent all-round.
Excellent budget tyre IMO is the Kumho KU31. Very well rated tyre and generally found for $99 in 195/50/15.
Cheers will I need to roll guards for the off set and the size? Or should I be right
I had 17x7 with 215 and +40 on my EH Civic. They rubbed at the rear, so you might need to roll your guards.
