Gearbox rebuilt, reinstalled- now car wont start
Hi guys - alittle bit of a difficult problem here.
I recently removed my l3 transmission , to replace a few bearings and clean it up - left my EG civic sitting disconnected for about 1 week - reinstalled the gearbox to all manual torque specs etc....seemingly installed everything back to where it belongs.
Now. I jumped in the drivers seat - and turned the key. The starter turns the motor over...struggling to ignite. Dam.
Ive checked almost everything -
BTW , before the gearbox getting taken out and reinstalled the car worked FINE.
* fuel pump is ok / fuel is being pumped through
*injectors are cycling
*There is spark , distributor is recently rebuilt.
*All loom is correctly reconnected - cant seem to see anything moved or crushed etc.
*Gearbox is not locked into any gear.
*battery is weak , but after testing a friends battery + distrutor + leads - the car still would not turn over.
*ground cables are reinstalled correctly.
*Checked all fuses - ECU , backup etc seem fine.
*main relay looks fine.
*Checked ECU codes - ECU is not hrowing any codes.
*When turning over , the car will ignite about 1 in 4 revolutions - BUT stall again. There is abit of white smoke blown out when this is happening........
I have been too busy to worry about this right now- but seriously WHAT should i look at checking out next ?
Is there something that i have totally missed....im starting to go alittle crazy about this !
Dave , John , anyone...advice please !
