I needed a new oxygen sensor, so yes I went and brought a new one, installed yet, tried to do an ecu reset (battery trick), turn the car on yet the CEL remains.
So the question is, do I need to clear the code to get rid of the CEL light?
Even after the oxygen sensor change the exhaust still smells rich and eggy, so would clearing the code fix this?
Another thing, is there any other fuses I should check to see if its blown (pretty much checked every fuse under the hood and under the steering wheel and none are blown).
Suggestions are welcome :)
