Originally Posted by
VT3C
LMFAO why u driving a Honda then ??? i think there is absolutely no point spending a cent on a single-banger NON VTEC.. the motors are meant for efficiency and re-grinding a stock cam can give you extended DURATION at the expense of LIFT.. that is unless you weld-on lumps of metal then grind it back down smooth.. but i'd personally never put a re-ground cam in my head !! too risky !! so what is the point of that ?
even if you bump the compression and fit i/h/e and an ecu tune your non vtec will be lucky to hit stock D16Y8 figures LOL.. the labour cost of a cam regrind and install and tune would prob be MORE than what it costs to do a swap.
if you dont want to be redlining it like an idiot for VTEC, then do a B18B or B20 swap.. yes it's a B-series but it has bucketloads of torque and even more HP than any single cam effort.. plus with the B20 all your power is there before 6,000RPM. match that to an EK4/EG6 gearbox and you got a quick and reliable daily driver with V6 like torque (when in a civic).
otherwise, i think you're in the wrong camp - go buy a VW golf and get soem torque in your life without being a 'Vtec idiot' HAHAHA.
