Just hope to get some info for registradtion of a new engine B16B to a civic eg GL
What i need to do and prepare for registradion?
woudlve been faster for you to go to vicroads website that make this damn thread!
http://vicroads.vic.gov.au/Home/Regi...ifications.htm
What chance would I have of registering a turbo dc2 from interstate in Victoria? It doesn't come with an engineering cert, its on REVS as a repairable write off. Is it worth it?
Would the engineering just be for RWC purposes?? What if I could get a Roadworthy and registered without the engineer cert? Would i still have trouble in the future? And how much are Engineering certs these days?
You'll be in trouble if you ever get pulled over, other than that.. how will they know? I know a lot of B18 and B16 conversions don't get engineered. That's a bit different though as a turbo is a bit more obvious. Also ,if it's a repairable write off then you'll need a VIV certificate too.
As stated before, too much hassle. Don't bother.
hey guys, didn't want to start a new thread for this topic but what happens if the car is bought interstate and was registered over there with a H22 into EK. do i need to get VASS here in melb before i can transfer registration with vicroads? or will a rwc suffice? thanks in advance!
If it's already engineered then I dont think you'll need to get a VASS. Best to clarify with VicRoads though.
I have called vicroads, they have advised me if the engine is already registered with the vehicle in another state. You wont have a problem transferring it over to victoria
nGGGG!
sorry to bump this back up.
just another similar question but this time, the vehicle is unregistered so either way ill need to go to vicroads for an inspection
but upon doing that I also wanted to do an engine conversion, nothing like a B16 or anything, just a D15B4 dual carb to a ZC.
I was reading on VicRoads about change of engines and it states 2 options:
Replacement engine is identical to the original engine, or is an option allowed by the manufacturer for the same model vehicle and Replacement engine is not of a type offered by the vehicle manufacturer as an option.
so how are we to verify that its a 'option' for the vehicle?
but either way, is it true ill still need an engineers certificate and a VASS certificate right? (not sure if its the same thing or not)
thanks for any help :)
Eeerr what? That's what everyone else has already said.
If the replacement engine was an option from the dealership then no need for engineering certificate. Just go take it to VicRoads and they'll register the engine to the chassis.
For example: You can go from a D16a8 to a D16y1 in an EG Civic as the D16y1 is from the EG Vti. However, you will need it engineered if you're going to a D16y4 because it was not released for the EG, only the EK.
What if i swap d15b4 to d16a8. if i get rwc with out changing rear brakes to drums. will they pass it in vic roads ??
engine same year 92
hey guys i got same problem
i want to do a engine swap.
got a '94 EG GLI would a ;
b16a/b18c need engineering?
thanks
Will b20 in an ef8 (originally b16) need a VASS?
cannot clearly decipher this by reading vicroads site.
Change of engine
1. Replacement engine is identical to the original engine, or is an option allowed by the manufacturer for the same model vehicle
The optional engine must be offered in Australia by the vehicle manufacturer as an option for that vehicle (or certified variants). The change of engine may be recorded by VicRoads provided that the registered operator or a motor mechanic, or dealer in that make of vehicle or an Automotive Engineer signs a declaration certifying the engine is optional for the vehicle model, and that all modifications made by the manufacturer for the same vehicle model with that optional engine have been completed.
You will need to attend a VicRoads Customer Service Centre to have the vehicle's engine inspected to confirm the new engine details. No appointment is required. You will also need to complete a Change of Vehicle Description form.
2. Replacement engine is not of a type offered by the vehicle manufacturer as an option for that vehicle or where alterations, or changes to the vehicle's frame or structure are made, and/or specially fabricated supports or structures are used
You will need to attend a VicRoads Customer Service Centre for an inspection of the vehicle to confirm the new engine details. You will also need to complete a Change of Vehicle Description form and provide VicRoads with:
- a VASS Approval Certificate from a VicRoads Vehicle Assessment Signatory
- an original receipt for the purchase of the engine as proof of ownership of the engine
3. Replacement engine is not of a type and/or make offered by the vehicle manufacturer as an option for that vehicle, but is equivalent in general configuration, power, mass, and emissions standard to that of the original or an optional engine for the vehicle model and can be installed without any structual alterations.
The change of engine may be recorded by VicRoads provided that the registered operator or a motor mechanic, or dealer in that make of vehicle or an Automotive Engineer signs a declaration certifying that all modifications made by the manufacturer for the same vehicle model with that engine, have been completed.
A Change of Vehicle Description form must be completed providing new engine details. An inspection to confirm engine details is also required unless a Certificate of Roadworthiness or VASS Approval Certificate including the new engine number is provided (only for a currently registered Victorian vehicle). An original receipt for the purchase of the engine must be provided as proof of ownership of the engine.
When a VASS Approval Certificate has been supplied for a replacement engine, then an equivalent replacement engine can be fitted without another VASS Approval Certificate being presented (eg 350 c.i. V8 engine replaced with 350 c.i. V8 engine).
yeah this seems to be newly added to the vicroads site.
In the case of b18c into eg, i think a VASS is no longer required, a stat dec from a mechanic will do. As long as there hasn't been any structual alterations have been done the chassis, which there won't be.
b20 in ef8 should be ok i think as well.
It states "but is equivalent in general configuration, power, mass, and emissions standard to that of the original or an optional engine for the vehicle model and can be installed without any structual alterations"
doesn't say anything about engine cc's .. as long as power, mass and emissions is equal or close to that of an optional engine (b16) and as long as there is no structual alterations ( i think this is the most important bit) then no VASS is needed i reckon.
Can anybody else confirm this???
