Just wondering does anyone know how i can make my D16Y4 rev higher and harder without spending too much? How high revs can you take a stock D16Y4 safely without worrying about damaging the engine?
Where is the redline?
Just because u can rev higher doesn't mean u will be making any more power than u are now.
As for making it rev higher u could get a piggy back ecu or u could disable ur limiter but i don't suggest that.
OR
I could just be totally wrong hehehe (most likely) :D
That's right.Quote:
If you want to rev higher, your head has to be able to handle it. It's easy to remove the limiter but if the engine is not designed to rev above the redline all the time you will eventually blow it up.
What is the redline for a D16Y4 engine? I just want to be able to rev a bit more freely. Right now it seems to struggle around 3,500-4,000 but i would have thought it can go a bit higher.
What do you mean what is the redline? Go and take a look?
:x
Your "vtec" should be loving it at 4000rpm!Quote:
Originally Posted by vince
what's the point of wanting to rev higher? your car stops making power after a certain point so why don't you find out where that point is :?:Quote:
good point mo :P
get an aftermarket ecu that will allow you to adjust fuel settings and fuel cut-off points
put it in neutral and slam the accelerator :P
but yeh u will need a replacement ecu/rev limit remover to go higher.....
What would be required to make the car make power at higher rev's ?
would you just need to replace the exhauset manifold and intake ?
or are other parts of the engine letting it down ?
-2ds
U will need an upgraded valve train atleast to rev higher and probably a better(more agressive) cam to take advantage of the higher rev's.
How much will this modify cost and will it be worth it? I'm trying to extract as much power out of my CXi without have to resort to engine swap. I don't really want to spend that much at the moment on it because i'll probably change car next year sometime.Quote:
Originally Posted by Weq
Save your money for when you're buying your next car
Don't waste your money - do a transplant instead.
I said I want to avoid a transplant.....oh well i guess i'll just save my money for a new car.Quote:
Originally Posted by Setanta
Eh I got no revs so I cant tell :cry:
